Use the default-height command to set the default height of the APs from the floor, for use if the floor plan does not specify a height for APs. The default-height command is accessible from the location context of the CLI.
| centimeters | Specifies the default height, in centimeters, of APs from the floor. Valid values are 0 - 1000. |
If the floor plan specifies a height for AP placement, that value will be used. If there is no floor plan, or the floor plan does not specify AP placement heights, then this command applies. The default value for the centimeters parameter is 3.
The following example sets the default height of APs to 06 centimeters:
EWC.extremenetworks.com:location# default-height 06 EWC.extremenetworks.com:location# apply
Print
                        this page
Email this topic
Feedback
