Use the name command to change the name of a role. The name command is accessible from within the the role:<named-role> context.
| new-name | Specifies the new name for this <named-role>. |
You must enter the apply command before exiting the role:<named-role> context for the role name change to take affect. The CLI prompt will not change until you exit and re-enter the role:<named-role> context.
The following example:
EWC.extremenetworks.com:role# p1 EWC.extremenetworks.com:role:p1# name role1 EWC.extremenetworks.com:role:p1# apply EWC.extremenetworks.com:role:p1# show Assigned topology: no change Ingress rate profile: no change Egress rate profile: no change Do not change filter settings when this Role is applied: disable Enable AP filtering: disable Name: role1 Synchronize: disable EWC.extremenetworks.com:role:p1# exit EWC.extremenetworks.com:role# role1 EWC.extremenetworks.com:role:role1#
Print
this page
Email this topic
Feedback
