Use the create command to create a new role, specifying a name for the new role. The create command is accessible from the role context.
| role-name | Specifies the name of the role. A role name can be made up of all alpha-numeric characters, as well as special characters: -!#$: |
The default values for a newly created role are:
The following example creates and then displays the details of a role named Auth:
EWC.extremenetworks.com:role# create Auth EWC.extremenetworks.com:role# show Auth Assigned topology: no change Ingress rate profile: no change Egress rate profile: no change Filter settings: enable Enable AP filtering: disable Name: Auth EWC.extremenetworks.com:role# show Auth acfilter Enable AP filtering: disable filter 1 (default) proto none 0.0.0.0 all_ports in dst out none allow filter 2 (default) proto none 0.0.0.0 all_ports in none out src allow
Print
this page
Email this topic
Feedback
