Use the show import_status command to display the import status of the text file, containing the controller's configuration.
None
The following example displays the import status of the text file, containing the controller‘s configuration:
EWC.extremenetworks.com# show import_status Import is in progress ………………… Current status is 60%
The following example displays the import status when the import of the text file is not running:
EWC.extremenetworks.com# show import_status Import process is not started
Print
                        this page
Email this topic
Feedback
