Use the hs-provider-methods command from the provider-config context to configure the hotspot OSU provider method.
| (method[,method]*) | Specifies the hotspot OSU provider methods. |
The following are valid methods: oma,soap.
They are case sensitive.EWC.extremenetworks.com:wlans:hs:hotspot# provider-config https://Enetworks.com
EWC.extremenetworks.com:wlans:hs:hotspot# hs-provider-methods oma, soap
Print
                        this page
Email this topic
Feedback
