The esaN command moves you into the context l2ports:esaN (where variable N refers to the physical data port number). This context contains the port command which enables or disables ports. This command is available on the following controllers: C25, V2110, C5110 and C5210. See port for information on enabling and disabling a port in this context.
Print
                        this page
Email this topic
Feedback
