Use the leftantenna-radio1 command to select an antenna supported by the Wireless AP. This command is accessible from the <serial> context of the CLI if the AP supports configuration of a left radio1 antenna. For AP models that support the Professional Install feature, leftantenna-radio1 is accessible from the ap:<serial>:professional_antenna# context. To display a list of the available antenna models, enter the command without arguments.
The antenna commands available are dependent on the AP type.
| antenna_model | Model name of an antenna supported by the Wireless AP. |
This example lists the valid antenna models that can be entered with this command, then executes the command with an appropriate model number:
EWC.extremenetworks.com:ap:0500010032150135 leftantenna-radio1 Usage: leftantenna-radio1 <antenna_model> antenna_model: <list of valid antenna models> WS-AO-2S03360 G 3.5 dBi Omni No Antenna EWC.extremenetworks.com:ap:0500010032150135 leftantenna-radio1 WS-AO-2S03360 G 3.5 dBi Omni
This example removes a configured left radio1 antenna:
EWC.extremenetworks.com:ap:0500010032150135# leftantenna-radio1 No Antenna
Print
                        this page
Email this topic
Feedback
