Use the direct-client-traffic command to enable or disable the blocking of direct client to client communication. The direct-client-traffic command is accessible from the wlans:<WLAN-service-name> context of the CLI.
After you run the direct-client-traffic command, run the apply command to implement the changes.
| enable | Specify to block direct client to client communication |
| disable | Specify to allow direct client to client communication |
The following example specifies to block direct client to client communication:
EWC.extremenetworks.com:wlans:test# direct-client-traffic enable EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show direct-client-traffic Block MU to MU traffic: enable
Print
                        this page
Email this topic
Feedback
