Use the hs-ccap command from the hotspot context to configure the connection capability for the hotspot.
| (add|delete) | Specifies whether to add or delete a connection capability. |
| (ah|udp|tcp|esp) | Specifies the protocol. |
| port | Specifies the port number in the range 0 to 65535. |
| (unknown|open|closed) | Specifies the port status. |
For protocols esp and ah the port number must be set to 0.
EWC.extremenetworks.com:wlans:hs:hotspot# hs-ccap add tcp 192 open
Print
                        this page
Email this topic
Feedback
