Use the enable command to enable or disable the guest portal access account
| id | Specifies the ID of the guest access account and must begin with the string “Guest-” |
The following example enables the guest access account:
EWC.extremenetworks.com:wlans:clients# enable Guest-lobby EWC.extremenetworks.com:wlans:clients# show Guest-lobby Lobby 1234abcd 2009-12-01 12:00:00 12 12 00:00 08:00 enabled
The following example disables the guest access account:
EWC.extremenetworks.com:wlans:clients# no enable Guest-lobby EWC.extremenetworks.com:wlans:clients# show Guest-lobby Lobby 1234abcd 2009-12-01 12:00:00 12 12 00:00 08:00 disabled
Print
                        this page
Email this topic
Feedback
