Use the aaa-redir command to enable or disable AAA redirect.
After you run the aaa-redir command, run the apply command to implement the changes.
| enable | disable | Specify to enable or disable AAA redirect |
The 8021x authentication mode must be set for this command to be available. For more information, see mode.
The following example enables AAA redirect:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# aaa-redir enable EWC.extremenetworks.com:wlans:cnl-AAA:auth# apply
Print
                        this page
Email this topic
Feedback
