Use this command to specify the type of captive portal redirection URL for successful logins. The send-login command is available from the wlan:<WLAN-service-name>:auth:captiveportal context.
| original-dest | Use the original destination value configured by the Wireless Assistant GUI. |
| cp-session | Use the captive portal session page value configured by the Wireless Assistant GUI. |
| custom | Use the custom specific URL value configured by the Wireless Assistant GUI. |
This example specifies that the type of successful login redirection URL is custom:
EWC.extremenetworks.com:wlans:Lab126-12-Int-CP:auth:captiveportal# send-login custom
Print
                        this page
Email this topic
Feedback
