This section describes commands for scheduling the backup of the following information:
This section describes commands which manage scheduling options for the backup of data locally or to an FTP or SCP address. The destination command setting specifies the destination where the export file is saved to. These commands are located in the schedule_backup context of the CLI.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
After running the schedule_backup commands, you must run the apply command to implement the changes.
The following commands are available in the schedule_backup context:
Print
                        this page
Email this topic
Feedback
