The capture-location command defines where the packets are to be captured on the selected AP. Use the associated keywords to define whether packets are to be captured on the AP's Ethernet port or the radio interfaces. Also define whether to capture incoming or outgoing packets, and whether or not to include clients packets in the capture.
| wired-direction in | out | both | Enables
wired-packet capture. If enabling wired-packet capture, use the following options to
specify the direction of packet flow:
| include-clients enable | disable | This is an optional parameter. When configured, it
includes packets received and/or transmitted to and from wired clients associated
with the AP.
| wireless-direction in | out | both | Enables wireless-packet capture. If enabling
wireless-packet capture, use the following options to specify the direction of
packet flow:
| radio radio1 | radio2 | both | Specifies the radio interface on which wireless-packet
capture is to be enabled.
Use the ap command to specify the AP before configuring packet capture parameters.
The following example configures packet capture location and direction on the wireless AP3912i:
EWC.extremenetworks.com:ap-traffic-capture# capture-location wired-direction both include-clients enable
