ExtremeWireless™ V10.41.07 CLI Reference Guide
Email this topic
Feedback
Download EPUB
Preface
Providing Feedback to Us
Getting Help
Extreme Networks Documentation
About This Guide
Who Should Use This Guide
How to Use This Guide
Introduction to the CLI
CLI Wizard
CLI Structure
Account Types
Common Commands
apply
end
exit
help
logout
no
show
root Commands
audit
ap-traffic-capture
ap
capture-duration
capture-status
capture-wired
capture-wireless
direction
filter-ip1 to filter-ip4
filter-mac1 to filter-mac2
max-packet
port
protocol
show capture-info
start
stop
use-filter-ip1 to use-filter-ip4
use-filter-mac1 to use-filter-mac2
availability
pair
pairip
pairrole
fast_failover
link_timeout
sync-config
sync-mu
backup
no backup
copy
host-attributes
hostname
domain
dns
dns
move
export
no export
flash
no flash
healthpoll
import
key
activate
ecap
lanset
loglevel
ping
radtest
radtest_mba
reset
restart
restore
secureconnection
secret
weak-ciphers
show
show ac version
show active-user
show ap (AP Configuration)
show ap_certificate
show ap_certreq
show ap_inventory
show app (Application Group)
show apup
show audits
show availability
show backup
show cdrs
show clients apserial
show clients vns
show run-config
show dns
show export
show flash
show healthpoll
show import
show import_status
show key
show l2ports
show lanset
show log
show loglevel
show ospf
show policy
show report channel_inspector
show role
show report
show restore
show routes
show schedule_ backup
show schedule_upgrade
show snmp
show stats
show syslog
show system_state
show tech_support
show time
show time-config
show topology
show traffic_capture
show upgrade
show upgrade_backup_dest
show upgrade_history
show upgrade_image_src
show users
show vnsmode
show vnsmode radius
show web
show wlans
shutdown
tech_support
traceroute
upgrade ac
upgrade apup
upgrade_backup_dest
upgrade_image_src
ap Commands
ap Context
access
blacklist
export
import
mac
mac-list-mode
mac-list-sync-mode
defaults
ap37xx
ap376x
ap38xx
ap3801
ap3805ROW
3912FCC and 3912ROW
3915FCC and 3915ROW
3916FCC and 3916ROW
3917FCC and 3917ROW
3935FCC, 3935ROW, 3935IL
3965FCC and 3965ROW
assign
wlans-list
wlan-foreign-ap
learnac
move
load-groups
create
delete
<named-load-group>
assign-ap
assign-radio
assign-wlan
bandpreference
name
radio-load
radio1-loadcontrol
radio2-loadcontrol
radio1-strictlimit
radio2-strictlimit
show
show
lpm-override
maintenance
upgrd
registration
cluster-encryption
cluster-shared-secret
dinterval
dretry
security
sshpasswd
remove
search
serial
<serial>
802_1x
eap
gen_certreq
peap
aclist
acws
ap_env
apip
balanced-power
bcast_disassoc
bgway
client_session
country
desc
iot-admin
iot-application
iot-eddystone-url
iot-ibeacon-major
iot-ibeacon-minor
iot-ibeacon-scan-dest-ip
iot-ibeacon-scan-dest-port
iot-ibeacon-scan-interval
iot-ibeacon-scan-min-rssi
iot-ibeacon-scan-uuid
iot-ibeacon-scan-window
iot-ibeacon-uuid
iot-interval
iot-thread-gateway-channel
iot-thread-gateway-extended-pan-id
iot-thread-gateway-master-key
iot-thread-gateway-network-name
iot-thread-gateway-short-pan-id
ipmcast-assembly
lacp
lbs-status
led-mode
lldp
location
move
name
persistent
poll_timeout
port-setting
professional_antenna
iot-antenna
leftantenna-radio1
leftantenna-radio2
middleantenna-radio1
middleantenna-radio2
rightantenna-radio1
rightantenna-radio2
AP3935e Ports
AP3915e Ports
AP3917e Ports
show
radio1
radio2
real_capture
remote-console
secure-tunnel
secure-tunnel-lifetime
show
ssh
tunnel-mtu
usedhcp
vlanid
wlan
zone
whitelist-iot
whitelist
Radio Commands
admin-mode
antsel
atpc
att
beaconp
ch
dcs
domain
dtim
force-disassociate
frag
ldpc
max-distance
mcast-adaptable
mcast2ucast
minbrate
mode
n_addba_support
n_aggr_mpdu
n_aggr_mpdu_max
n_aggr_mpdu_max_subframes
n_aggr_msdu
n_chlwidth
n_guardinterval
n_pbthreshold
n_pmode
n_ptype
nonUnicastQuota
optimized-mcast
pmode
prate
preamble
probe-suppression
ptype
radio-actions
rss-threshold
rts
stbc
tx_adjust_power
txbf
tx_max_power
tx_min_power
DCS Commands
channel_plan
interference-event-type
interference-wait-time
mode
noise_threshold
occupancy_threshold
radio_channels
update_period
logs Context
aplist
collection
destination
frequency
maintain_cycle Context
duration
platform
freq
l2ports Commands
esaN
jumbo-frames
portN
port
show
<named-LAG-port>
lag-member
port
ip Commands
route
ospf
area
areatype
routerid
status
ospfinterface
add-ospf-interface
delete-ospf-interface
<named-ospfinterface>
authkey
authtype
deadinterval
hellointerval
linkcost
retransmitinterval
status
transmitdelay
login Commands
apply
auth
server
primary
authset
move
radtest_login
auth-order
move
show
Radar Commands
mitigator Context
adsprof
<named ad profile>
shareprof
<named share profile>
radio-share-mode
create
delete
server<#>
analysis
scprof
create
delete
<named scan profile>
gsprof
create
delete
<named guardian scan profile>
maintenance
authorized-ap
friendly-ap
prohibited-ap
reclassify
show
Common Scan/Profile Commands
adhoc
aplist
blacklist-timer
channels
classification
concurrent-number
dosa
drop-faf
external-friendly
external-honeypot
internal-honeypot
name
port
rogue
rogue-prevent
security-scan
spoofed-ap
show
mobility Commands
backupmanagerip
mrole
mport
mheartbeat
slpreg
agent
secmode
mdismethod
mmanagerip
schedule_backup Commands
destination
dir
freq
password
protocol
server
starttime
type
user
schedule_upgrade Commands
schld_upgrd
upgrade_backup
snmp Commands
contact
context
enable
engine-id
location
port
publish-ap
rcommunity
rwcommunity
severity
show
trap-manager-v1v2
trap-manager-v3
user
syslog Commands
audmsg
facility
stationevents
svcmsg
syslogip
time Commands
clock
date
ntp
ntpip
show-continents
show-regions
tz
traffic_capture Commands
file_name
size
interface
delete
list
start
stop
show
show interfaces
users Commands
id
pwd
VNS Commands (vnsmode)
adminctr
auto-login
egress-filtering
flex-client-access
hybrid-policy
max-beffort-assoc
max-beffort-reassoc
max-bground-assoc
max-bground-reassoc
max-video-assoc
max-video-reassoc
max-voice-assoc
max-voice-reassoc
policy-invalid-action
rule-redirect
tg-selection
vlan-policy
wlan-airtime
create
custom-app
custom-app-list
das
port
replay_interval
default-role
show
sync
topology-name
acfilters
apfilters
delete
nac
create
delete
show
netflow-mirror
netflow-export-dest
netflow-export-interval
traffic-mirror-firstn
traffic-mirror-l2port
radius
create
defer-acct-start
delay-client-msg
delete
include-service-type
show
radius-accounting
radius-mac-format
rename
service-type-login
strict
usage-mode
<named_RADIUS_server>
acct-port
acct-prio
acct-retries
acct-timeout
auth-port
auth-prio
auth-retries
auth-timeout
fast-failover
interim
ip
name
polling-interval
polling-mechanism
protocol
shared-secret
mac-format-1x
rateprofile
create
delete
show
redirection-url-list
<named-VNS>
auth
non-auth
name
status
sync
wlans-name
show
Common Filter Configuration Commands
create
config
delete
move
wlans Commands
clients
client
descr
enable
endofday
export_clients
import_clients
startofday
create
delete
remote-ssid
show
<WLAN-service-name>
3pap
aplist
aplist-wds (WDS)
aplist-wds (Mesh)
appl-visibility
auth
aaa-redir
access-reject-without-cui
captiveportal
add-ap-eth-mac
add-ap-location
add-ip-port
copy-cpfile
cp-ssl
custom
extcpip
extredir
extsecret
fqdn
guestportalacctlifetime
guestportalprefix
maxsessionlifetime
minpasswdlength
pwd-charset
pwd-ignore-similar
pwd-pattern
pwd-pattern-select
redirect
send-login
set-acct-lifetime
tos-override
cdr
config
config exit
fast-failover
include-cui-type
interim
mac
mac-acct
mac-auto-authenticate
mac-allow-unauthorized
mac-roam
mode
move
nasid
nasip
password
protocol
radius-timeout-policy
remove
show
use-zone
vsa-ap
vsa-egress
vsa-ingress
vsa-policy
vsa-ssid
vsa-topology
vsa-vns
backhaul-radio
cp-http
default-cos
default-topology
default-traffic-mirror
direct-client-traffic
egress-filtering
interwlan-roaming
name
netflow
priv
fast-transition
group-key-ps
mfp
mode
wep
wpa-broadcast-rekey
wpa-v1
wpa-v2
wpa-v2-key-mgmt
psk
qos-policy
beffort-admission-control
bground-admission-control
dot11e
downlink
flex-client-access
legacy
priority-map
priority-override
priority-override-dscp
priority-override-up
turbo-voice
uapsd
uplink
wmm
video-admission-control
voice-admission-control
remoteable
rf
11h-power-reduction
11h-support
11k-beacon-rep
11k-quiet-ie
11k-support
energy-save-mode
process-client-ie
show
ssid-suppress
show
ssid
status
sync
timeout-post
timeout-pre
timeout-session
unauth-behaviour
hotspot
hs-3gpp
hs-ant
hs-ccap
hs-dgaf
hs-domain
hs-down-load
hs-down-speed
hs-hessid
hs-internet-avail
hs-nai-realm
hs-natype
hs-ofn-venue
hs-osu
hs-rc
hs-up-load
hs-up-speed
hs-v4avail
hs-v6avail
hs-venue-group
hs-venue-type
Venue Group - Type Values
provider-config
hs-provider-desc1
hs-provider-desc2
hs-provider-frn1
hs-provider-frn2
hs-provider-icon
hs-provider-lang1
hs-provider-lang2
hs-provider-methods
hs-provider-nai
hs-provider-uri
remove
apply
Language Codes
redirect-url
role Commands
role Context
create
delete
show
<named-role>
access-control
default-cos
egress-vlans
name
filter-status
sync
ulfilterap
apcustom
acfilters
apfilters
show
traffic-mirror
redirection-url
create
config
delete
move
topology Commands
create
delete
internal-vlanid
multicast-support
show
<named-topology>
3rd-party
isid
l2
arp-proxy
multicast
config
create
delete
filter
move
show
port
show
tagged
vlanid
l3
ap-register
cert
copy-csr
dhcp
dhcp-servers
dls
dls-address
dns
domain
exclude
foreign-gateway
foreign-range
gateway
lease-default
lease-max
mode
range
show
wins
exceptions
config
create
delete
move
show
foreign-ip
gateway
gateway-ipv6
gen-certreq
ip
ipv6
mgmt
mtu
netmask
nexthop
ospf-advert
ospf-cost
show
l3presence
mode
name
show
strict-subnet
sync
topology-group
create
delete
show
<topology-group-name>
members
name
show
vlanid
Location-Based-Service (lbs) Commands
multicast
port
service
server-ip
show
Related commands
lbs-status
show
web Commands
guestportal-admin-timeout
timeout
showvns
show
cos Commands
create
delete
show
<named-cos>
show
name
sync
use-wlan-marking
priority
tos-dscp-mask
rateprf-in
rateprf-out
transmit-queue
site Commands
create
delete
show site
<named-site>
assign-ap
assign-policy
assign-wlan
band-preference
config
custom
dns
local-radius
move
name
nasid
nasip
password
ping
protocol
radio1-load
radio2-load
radio1-loadcontrol
radio2-loadcontrol
radio1-strictlimit
radio2-strictlimit
remove
replace-station-id
secure-tunnel
secure-tunnel-ap
secure-tunnel-control
show
RF Location Commands
area-tracking
auto-tracking
default-env-mode
default-height
floor-plan
export
import
delete
location-engine
on-demand
publish
show
elocation
elocation-support
address
aplist
min-rss
report-freq
tenant-id
Publish Commands
push
interval
unit
push-list
push-ap-reporting
push-client-reporting
Configuring Roles
