Eddystone-url ScanNEW!
BLE-enabled APs capture beacons and send them to a configured Application Server. Upon reception, the server application triggers possible actions such as updating statistics related to beacon location or communicating with a mobile device application.
An AP scans for beacons, filtering data based on configuration parameters and reports findings to an Application Server. ExtremeWireless forwards the report as a JSON message to the customer's Application Server. The report includes the following data:
  • AP Serial Number
  • The MAC address of the beacon tag
  • Decoded URL
  • Device transmission power
  • The signal strength of the iBeacon tag
The following filters can be applied at the AP to specify the message stream:
  • Minimum Received Signal Strength Indicator (RSSI). Transfers messages that meet the configured RSSI threshold. Messages received with an RSSI below the configured threshold are omitted.
Only scanned frames with Eddystone-url format are supported. The UUID must be 0xFEAA.
Refer to the Integration Guide for details on the format of the beacon RTLS message.
The customer's Application Server handles the business logic and presentation of the IoT report. The Application Server:
  • Calculates the distance between the BLE tag and the AP, based on the signal strength for the tag/radio channel
  • Maps AP Serial Number to a physical location
  • Tracks BLE tags.
From ExtremeWireless, configure Eddystone-url Scan parameters under AP configuration.
