Enabling Management Traffic
If management traffic is enabled for a VNS, it overrides the built-in exception filters that prohibit traffic on the controller data interfaces. For more information, see Policy Rules.
To enable management traffic for a topology:
  1. From the top menu, click either Controller or VNS. Then, in the left pane, select Topologies.
  2. Select the desired physical or Routed topology. If the Layer 3 parameters are not displayed, check the Layer 3 check box.
  3. Select the Management Traffic check box.
  4. Click Save.
