Including Custom Apps
To add custom apps to the L7 Filter Rule
Definition dialog:
From the Filter Rule
Definition dialog, select L7.
Click Custom Web Application.
Click the plus sign and enter the following:
Adding Custom Web Applications
Click OK.
The
list displays.
Custom Web Applications List
Select the check box and click OK to add the custom app to
the Name drop-down field on the L7 Configuration
dialog.
L7 Configuration: Custom Apps with hostname
rule
