Whitelist Node Parameters
Create a whitelist of approved nodes for the Thread Network. The IoT whitelist applies to all APs that are configured for Thread Gateway associated with the controller.
Use the long EUI for each sensor and the pre-shared password. The short EUI is not used. Currently, the whitelist can be comprised of a maximum 32 nodes.
Node Parameters
Field Description
EUI Extended Unique Identifier for each sensor node, determined by the sensor manufacturer.
Password Pre-shared password. Sensor passwords are created when the sensor is commissioned, outside of ExtremeWireless. The default password is THREAD.
