proxy-nd-mode
    Configures the proxy ND mode for this
      WLAN member clients as either strict or dynamic. ND proxy is used in IPv6 to provide
      reachability by allowing a client to act as proxy. Proxy certificate signing can be done
      either dynamically (requiring exchanges of identity and authorization information) or
      statically when the network topology is defined.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      proxy-nd-mode [dynamic|strict]
    Parameters
              | proxy-nd-mode [dynamic|strict] | Configures the proxy ND mode for this WLAN member clients. The options are:
                dynamic and strict
                  dynamic – Forwards ND request
                    to wireless for which a response could not be proxied. This is the default
                    value.strict – Does not forward ND
                    requests to the wireless side |
      nx9500-6C8809(config-wlan-test)#proxy-nd-mode strict
      nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode tunnel
 encryption-type none
 authentication-type none
 wpa-wpa2 server-only-authentication
 opendns device-id 44-55-66
