ex3500-qos-policy-map
    Creates an EX3500
      policy map and enters its configuration modeAn EX3500 policy map
        contains one or more EX3500 QoS class maps traffic classifications
        (existing and configured) and can be attached to multiple interfaces.
        Create a EX3500 policy map, and then use the class parameter to
        configure policies for traffic that matches the criteria defined in the
        EX3500 QoS class map policy. For more information, see match.
    Supported in the
        following platforms:
        - Service Platforms —
          NX7500, NX9500, NX9600, VX9000
Syntax
      ex3500-qos-policy-map <EX3500-QOS-POLICY-MAP-NAME>
    Parameters
              | <EX3500-QOS-POLICY-MAP-NAME> | Specify the EX3500 policy map‘s name |
      nx9500-6C8809(config)#ex3500-qos-policy-map testPolicyMap
nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap)#?
nx9500-6C8809_Qos_policy_map Mode commands:
  class        Defines a traffic classification for the policy
  description  Policy-map description
  no           Negate a command or set its defaults
  clrscr       Clears the display screen
  commit       Commit all changes made in this session
  do           Run commands from Exec mode
  end          End current mode and change to EXEC mode
  exit         End current mode and down to previous mode
  help         Description of the interactive help system
  revert       Revert changes
  service      Service Commands
  show         Show running system information
  write        Write running configuration to memory or terminal
    Related Commands
              | no | Removes an existing EX3500 QoS policy map |
