NetFlow is a Cisco-proprietary protocol that collects IP flow data and exports it to a NetFlow Collector. IP flow data provides a highly granular insight of the network and facilitates fine-grained metering for highly flexible and detailed resource usage accounting.
IP flow data is exported by the APs to the NetFlow Collector using templates that contain supporting data record fields.
To enable IP flow data collection and export within your WiNG 7.3.0 managed network, create a NetFlow policy and apply locally on the AP or in the AP's profile context. The NetFlow policy identifies the Collector host and specifies the interval at which templates are exported to the specified Collector.
NetFlow is supported only on the new 802.11ax APs. The NetFlow policy can be configured on the controller (NX5500, NX7500, NX9500, NX9600) and pushed to the AP. Or, you can configure the policy locally on the AP and use it in the AP's device or profile context.netflow-policy <NETFLOW-POLICY-NAME>
| <NETFLOW-POLICY-NAME> | Specify the NetFlow policy name. If a policy with the specified name does not already exist, it is created. |
nx9500-6C8809(config)#netflow-policy test nx9500-6C8809(config-netflow-policy-test)#? Netflow Policy Mode commands: collector Netflow collector interval Netflow Template refresh interval no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-netflow-policy-test)#
Apply the NetFlow policy to the AP's profile.
nx9500-6C8809(config)#profile ap505 test505 nx9500-6C8809(config-profile-test505)#use netflow-policy test
nx9500-6C8809(config-profile-test505)#show context include-factory | include netflow-policy use netflow-policy test nx9500-6C8809(config-profile-test505)#
Or, apply the NetFlow policy locally on the AP:
nx9500-6C8809(config)#ap505 94-9B-2C-13-40-38 nx9500-6C8809(config-device-94-9B-2C-13-40-38)#use netflow-policy test
nx9500-6C8809(config-device-94-9B-2C-13-40-38)#show context include-factory | include netflow-policy use netflow-policy test nx9500-6C8809(config-device-94-9B-2C-13-40-38)#
| no (global-config-context) | Removes an existing NetFlow policy |
| use (profile/device-config-mode-commands) | Associates the NetFlow policy to the AP's (AP4xx and AP5xx) profile or device. |
