storm-control
Enables storm control on the firewall policy
Storms are packet bombardments that exceed the high threshold value configured for an interface. During a storm, packets are throttled until the rate falls below the configured rate, severely impacting performance for the RF Domain manager interface.
Storm control limits multicast, unicast and broadcast frames accepted and forwarded by a device. Messages are logged based on their severity level.
Syntax
storm-control [arp|broadcast|multicast|unicast]
storm-control [arp|broadcast|multicast|unicast] [level|log]
storm-control [arp|broadcast|multicast|unicast] level <1-1000000>
[fe <1-4>|ge <1-8>|port-channel <1-8>|up1|wlan <WLAN-NAME>]
storm-control [arp|broadcast|multicast|unicast] log [<0-7>|alerts|critical|
debugging|emergencies|errors|informational|none|notifications|warnings]
Parameters
arp
Configures storm control for ARP packets
broadcast
Configures storm control for broadcast packets
multicast
Configures storm control for multicast packets
unicast
Configures storm control for unicast packets
level <1-1000000>
Configures the allowed number of packets received per second before storm control begins
  • <1-1000000> – Sets the number of packets received per second
fe <1-4>
Sets the FastEthernet port for storm control from 1 - 4
ge <1-8>
Sets the GigabitEthernet port for storm control from 1 - 8
port-channel <1-8>
Sets the port channel for storm control from 1- 8
up1
Sets the uplink interface
wlan <WLAN-NAME>
Configures the WLAN
  • <WLAN-NAME> – Sets the WLAN ID for the storm control configuration
storm-control [arp|bcast|multicast|unicast] log [<0-7>|alerts|critical|debugging|
arp
broadcast
multicast
unicast
log
Configures the storm control log level for storm control events
<0-7>
Sets the numeric logging level from 0 - 7
alerts
Numerical severity 1. Indicates a condition where immediate action is required
critical
Numerical severity 2. Indicates a critical condition
debugging
Numerical severity 7. Debugging messages
emergencies
Numerical severity 0. System is unusable
errors
Numerical severity 3. Indicates an error condition
informational
Numerical severity 6. Indicates a informational condition
none
Disables storm control logging
notification
Numerical severity 5. Indicates a normal but significant condition
warnings
Numerical severity 4. Indicates a warning condition
nx9500-6C8809(config-fw-policy-testFW)#storm-control arp log warnings
nx9500-6C8809(config-fw-policy-testFW)#storm-control broadcast level 2
nx9500-6C8809(config-fw-policy-testFW)#show context
firewall-policy testFW
 ip dos fraggle drop-only
 ip dos tcp-sequence-past-window drop-only
 ip dos tcp-max-incomplete high 600
 ip dos tcp-max-incomplete low 60
 storm-control broadcast level 20000 ge 4
 ip-mac conflict drop-only
 ip-mac routing conflict log-and-drop log-level notifications
 flow timeout icmp 16000
 flow timeout udp 10000
 flow timeout tcp established 1500
 flow timeout other 16000
 dhcp-offer-convert
 ipv6 routing-type two log-and-drop log-level warnings
 ipv6 dos hop-limit-zero drop-only
 alg facetime
 logging icmp-packet-drop rate-limited
 logging malformed-packet-drop all
 logging verbose
 dns-snoop entry-timeout 1200
 ipv6-mac routing conflict drop-only
Related Commands
no
Disables storm control limits on multicast, unicast, and broadcast frames accepted and forwarded by a device
