Creates a permit rule that accepts packets from a specified IPv6 source and/or addressed to a specified IPv6 destination. You can also use this command to modify an existing permit rule.
permit [icmpv6|ipv6|proto|tcp|udp]
permit icmpv6 [<SOURCE-IPv6/MASK>|any|host <SOURCE-HOST-IPv6>] [<DEST-IPv6/MASK>|any|
host <DEST-HOST-IPv6>] [code [eq <ICMPv6-CODE>|range <STARTING-ICMPv6-CODE> <ENDING-ICMPv6-CODE>]|
type [eq <ICMPV6-TYPE>|range <STARTING-ICMPv6-TYPE> <ENDING-ICMPv6-TYPE>]]
(log,rule-precedence <1-5000>) {(rule-description <LINE>)}
      permit ipv6 [<SOURCE-IPv6/MASK>|any|host <SOURCE-HOST-IPv6>] [<DEST-IPv6/MASK>|any|
host <DEST-HOST-IPv6>] (log,rule-precedence <1-5000>) {(rule-description <LINE>)}
      permit proto [<PROTOCOL-NUMBER>|<PROTOCOL-NAME>|eigrp|gre|igp|ospf|vrrp]
[<SOURCE-IPv6/MASK>|any|host <SOURCE-HOST-IPv6>] [<DEST-IPv6/MASK>|any|host <DEST-HOST-IPv6>]
      permit [tcp|udp] [<SOURCE-IPv6/MASK>|any|host <SOURCE-HOST-IPv6>] [<DEST-IPv6/MASK>|any|
eq <SOURCE-PORT>|host <DEST-HOST-IPv6>|range <START-PORT> <END-PORT>] [eq [<1-65535>|<
SERVICE-NAME>|bgp|dns|ftp|ftp-data|gopher|https|ldap|nntp|ntp|pop3|sip|smtp|ssh|telnet|tftp|www]|
range <START-PORT> <END-PORT>] (log,rule-precedence <1-5000>) {(rule-description <LINE>)}
      | icmpv6 | Applies this permit rule to ICMPv6 packets only |
| <SOURCE-IPv6/MASK> | Specifies a range of IPv6 source address (network) to match. ICMPv6 packets received from any source in the specified network are forwarded. |
| any | Specifies the source as any IPv6 address. ICMPv6 packets received from any source are forwarded. |
| host <SOURCE-HOST-IPv6> | Identifies a specific host (as the source to match) by
                its IPv6 address. ICMPv6 packets received from the specified host are forwarded.
| <DEST-IPv6/MASK> | Specifies a range of IPv6 destination address (network) to match. ICMPv6 packets addressed to any destination within the specified network are forwarded. |
| any | Specifies the destination as any IPv6 address. ICMPv6 packets addressed to any destination are forwarded. |
| host <DEST-HOST-IPv6> | Identifies a specific host (as the destination to match)
                by its IPv6 address. ICMPv6 packets addressed to the specified host are forwarded.
| <ICMPv6-TYPE> [eq|range] | Defines the ICMPv6 type field filter
 Note: ICMPv6 packets with type field value matching the
                  values specified here are forwarded. |
| <ICMPv6-CODE> | Defines the ICMPv6 code field filter
 Note: ICMPv6 packets with code field value matching the values specified here
                  are forwarded. |
| log | Logs all permit events matching this entry |
| rule-precedence <1-5000> | Assigns a precedence for this permit rule
 Note: Lower the precedence higher is the priority. A rule
                  with precedence 3 gets priority over a rule with precedence 10. |
| rule-description <LINE> | Optional. Configures a description for this permit rule. Provide a description that uniquely identifies the purpose of this rule (should not exceed 128 characters in length). |
      | ipv6 | Applies this permit rule to IPv6 packets only |
| <SOURCE-IPv6/MASK> | Specifies a range of IPv6 source address (network) to match. IPv6 packets received from any source in the specified network are forwarded. |
| any | Specifies the source as any IPv6 address. IPv6 packets received from any source are forwarded. |
                its IPv6 address. IPv6 packets received from the specified host are forwarded.
| <DEST-IPv6/MASK> | Specifies a range of IPv6 destination address (network) to match. IPv6 packets addressed to any destination within the specified network are forwarded. |
| any | Specifies the destination as any IPv6 address. IPv6 packets addressed to any destination are forwarded. |
                by its IPv6 address. IPv6 packets addressed to the specified host are forwarded.
      | proto | Configures the ACL for additional protocols Additional protocols (other than IP, ICMP, TCP, and UDP) must be configured using this parameter. |
| <PROTOCOL-NUMBER> | Filters protocols using their IANA protocol number
| <PROTOCOL-NAME> | Filters protocols using their IANA protocol name
| eigrp | Identifies the EIGRP protocol (number 88) EIGRP enables routers to maintain copies of neighbors‘ routing tables. Routers use this information to determine the fastest route to a destination. When a router fails to find a route in its stored route tables, it sends a query to neighbors who in turn query their neighbors till a route is found. EIGRP also enables routers to inform neighbors of changes in their routing tables. |
| gre | Identifies the GRE protocol (number 47) GRE is a tunneling protocol that enables transportation of protocols (IP, IPX, DEC net, etc.) over an IP network. GRE encapsulates the packet at the source and removes the encapsulation at the destination. |
| igp | Identifies any private internal gateway (primarily used
                by CISCO for their IGRP) (number 9) IGP enables exchange of information between hosts and routers within a managed network. The most commonly used IGP protocols are: RIP and OSPF. |
| ospf | Identifies the OSPF protocol (number 89) OSPF is a link-state IGP. OSPF routes IP packets within a single routing domain (autonomous system), like an enterprise LAN. OSPF gathers link state information from neighbor routers and constructs a network topology. The topology determines the routing table presented to the Internet Layer which makes routing decisions based solely on the destination IP address found in IP packets. |
| vrrp | Identifies the VRRP protocol (number 112) VRRP allows a pool of routers to be advertized as a single virtual router. This virtual router is configured by hosts as their default gateway. VRRP elects a master router, from this pool, and assigns it a virtual IP address. The master router routes and forwards packets to hosts on the same subnet. When the master router fails, one of the backup routers is elected as the master and its IP address is mapped to the virtual IP address. |
| <SOURCE-IPv6/MASK> | Specifies a range of IPv6 source address (network) to match. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from any source in the specified network are forwarded. |
| any | Specifies the source as any IPv6 address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from any source are forwarded. |
                its IPv6 address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the
| <DEST-IPv6/MASK> | Specifies a range of IPv6 destination address (network) to match. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to any destination within the specified network are forwarded. |
| any | Specifies the destination as any IPv6 address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to any destination are forwarded. |
                by its IPv6 address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to the
eq <SOURCE-PORT>|host <DEST-HOST-IPv6>|range <START-PORT> <END-PORT>] [eq [<1-65535>|<SERVICE-NAME>|
      | tcp | Applies this permit rule to TCP packets only |
| udp | Applies this permit rule to UDP packets only |
| <SOURCE-IPv6/MASK> | This keyword is common to the ‘tcp‘ and ‘udp‘
                  parameters. Specifies a range of IPv6 source address (network) to match. TCP/UDP packets received from any source in the specified network are forwarded. |
| any | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies the source as any IPv6 address. TCP/UDP packets received from any source are forwarded. |
                its IPv6 address. TCP/UDP packets received from the specified host are forwarded.
| <DEST-IPv6/MASK> | This keyword is common to the ‘tcp‘ and ‘udp‘
                  parameters. Specifies a range of IPv6 destination address (network) to match. TCP/UDP packets addressed to any destination within the specified network are forwarded. |
                  parameters. Specifies the destination as any destination IPv6 address. TCP/UDP packets received from any destination are forwarded. |
| eq <SOURCE-PORT> | Identifies a specific source port
| host <DEST-HOST-IP> | Identifies a specific host (as the destination to match)
                by its IPv6 address. TCP/UDP packets addressed to the specified host are forwarded.
| range <START-PORT> <END-PORT> | Specifies a range of source ports
| eq [<1-65535>| <SERVICE-NAME>| |bgp|dns|ftp| ftp-data|gropher| https|ldap|nntp|ntp| pop3|sip|smtp| ssh|telnet| tftp|www] | Identifies a specific destination or protocol port to
                  match
| range <START-PORT> <END-PORT> | Specifies a range of destination ports
nx9500-6C8809(config-ipv6-acl-test)#ermit proto gre any any log rule-precedence 2
      nx9500-6C8809(config-ipv6-acl-test)#show context ipv6 access-list test deny icmpv6 any any type eq destination-unreachable code eq router-renumbering-command log rule-precedence 1 permit proto gre any any log rule-precedence 2 nx9500-6C8809(config-ipv6-acl-test)#
| no (ipv6-acl) | Removes a specified permit access rule from this IPv6 ACL |
