bridging-mode
      Configures the mode used to bridge
         packets to and from a WLAN. Use this command to define which VLANs are bridged, and how
         local VLANs are bridged between the wired and wireless sides of the network.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         bridging-mode [local|tunnel]
      Parameters
                     | bridging-mode | Configures bridging mode on this WLAN. The options are
                           local and tunnel. |
                     | local | Bridges packets between WLAN and local ethernet
                        ports. This is the default mode. |
                     | tunnel | Tunnels packets to other devices (typically a
                        wireless controller or service platform) |
         nx9500-6C8809(config-wlan-test)#bridging-mode local
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
bridging-mode local
 encryption-type none
 authentication-type eap
 accounting syslog host 172.16.10.4 port 2
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
