disable [deny|insert|permit]
disable [deny|insert [deny|permit]|permit] [<NETWORK-SERVICE-ALIAS-NAME>|dns-name| icmp|ip|proto|tcp|udp]
disable [deny|insert [deny|permit]|permit] [<NETWORK-SERVICE-ALIAS-NAME>| dns-name [contains|exact|suffix]|icmp|ip|proto <PROTOCOL-OPTIONS>|tcp|udp] [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|host <DEST-HOST-IP>] (log,mark [8021p <0-7>| dscp <0-63>],rule-precedence)
| disable [deny| insert [deny|permit]| permit] | Disables a deny or permit access rule without
                        removing it from the ACL This command also enables the insertion of a disable deny or permit rule without overwriting an existing rule in the IP ACL. Note: To disable an existing deny/permit rule, provide the
                           exact values used to configure the deny or permit rule. |
| <NETWORK-SERVICE-ALIAS-NAME> | Specifies the network-service alias, identified by the <NETWORK-SERVICE-ALIAS-NAME> keyword, associated with the deny/permit rule |
| dns-name [contains| exact|suffix] | Specifies the packets to reject based on the dns-name match. Applies this deny rule to packets based on dns-names specified in the network-service |
| icmp | Disables a rule applicable to ICMP packets only |
| ip | Disables a rule applicable to IP packets only |
| proto <PROTOCOL-OPTIONS> | Disables a rule applicable to any Internet
                        protocol other than TCP, UDP, or ICMP packets
| tcp | Disables a rule applicable to TCP packets only |
| udp | Disables a rule applicable to UDP packets
                           only Note: After specifying the packet type, specify the source and
                           destination devices and network address(es) to match. |
| <SOURCE-IP/MASK> | Specify the source IP address and mask in the A.B.C.D/M format. |
| <NETWORK-GROUP-ALIAS-NAME> | Specifies the network-group alias, identified by the <NETWORK-GROUP-ALIAS-NAME> keyword, associated with this deny/permit rule |
| any | Select ‘any‘ if the rule is applicable to any source IP address. |
| from-vlan <VLAN-ID> | Specify the VLAN IDs. |
| host <SOURCE-HOST-IP> | Specify the source host‘s exact IP address. |
| <DEST-IP/MASK> | Specify the destination IP address and mask in the A.B.C.D/M format. |
| any | Select ‘any‘ if the rule is applicable to any destination IP address. |
| host <DEST-HOST-IP> | Specify the destination host‘s exact IP address. |
| log | Select log, if the rule has been configured to log records in case of a match. |
| mark [8021p <0-7>| dscp <0-63>] | Specifies packets to mark
| rule-precedence <1-5000> | Specify the rule precedence. The deny or permit rule with the specified precedence is disabled. Note: To enable a disabled rule, enter the rule again without the ‘disable‘
                           keyword. Note: The no > disable command removes a disabled rule from the ACL. |
The following example shows the ‘auto-tunnel-acl‘ settings before the disable command is executed:
nx9500-6C8809(config-ip-acl-auto-tunnel-acl)#show context ip access-list auto-tunnel-acl deny ip host 200.200.200.99 30.30.30.1/24 rule-precedence 2 permit ip host 200.200.200.99 any rule-precedence 3 nx9500-6C8809(config-ip-acl-auto-tunnel-acl)#
nx9500-6C8809(config-ip-acl-auto-tunnel-acl)#disable permit ip host 200.200.200.99 any rule-precedence 3
The following example shows the ‘auto-tunnel-acl‘ settings after the disable command is executed:
nx9500-6C8809(config-ip-acl-auto-tunnel-acl)#show context ip access-list auto-tunnel-acl deny ip host 200.200.200.99 30.30.30.1/24 rule-precedence 2 disable permit ip host 200.200.200.99 any rule-precedence 3 nx9500-6C8809(config-ip-acl-auto-tunnel-acl)#
nx9500-6C8809(config-ip-acl-test)#deny icmp any any log rule-precedence 1
         nx9500-6C8809(config-ip-acl-test)#show context ip access-list test deny icmp any any rule-precedence 1 nx9500-6C8809(config-ip-acl-test)#
nx9500-6C8809(config-ip-acl-test)#disable deny icmp any any rule-precedence 1
         nx9500-6C8809(config-ip-acl-test)#show context ip access-list test disable deny icmp any any rule-precedence 1 nx9500-6C8809(config-ip-acl-test)#
nx9500-6C8809(config-ip-acl-test)#show context ip access-list test deny tcp from-vlan 1 any any rule-precedence 1 permit icmp any host 192.168.13.7 1 1 rule-precedence 2 nx9500-6C8809(config-ip-acl-test)#
nx9500-6C8809(config-ip-acl-test)#disable insert deny ip any any log rule-precedence 2
nx9500-6C8809(config-ip-acl-test)#show context ip access-list test deny tcp from-vlan 1 any any rule-precedence 1 disable deny ip any any log rule-precedence 2 permit icmp any host 192.168.13.7 1 1 rule-precedence 3 nx9500-6C8809(config-ip-acl-test)#
| no (ipv4-acl) | Enables a disabled deny or permit rule |
| alias | Creates and configures a aliases (network, VLAN, service, etc.) |
