ip
      Displays IP related
         information
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         show ip [arp|bgp|ddns|default-gateways|dhcp|dhcp-vendor-options|domain-name|
extcommunity-list|igmp|interface|name-server|nat|ospf|route|routing]
         show ip arp {<VLAN-NAME>} {(on <DEVICE-NAME>)}
         show ip bgp {<IP>|<IP/M>|community|community-list|filter-list|neighbors|
on|paths|prefix-list|regexp|route-map|state|summary}
         show ip ddns bindings {on <DEVICE-NAME>}
         show ip dhcp [binding|networks|status]
         show ip dhcp binding {manual} {(on <DEVICE-NAME>)}
         show ip dhcp [networks|status] {on <DEVICE-NAME>}
         show ip [default-gateways|dhcp-vendor-options|domain-name|name-server|routing]
{on <DEVICE-NAME>}
         show ip extcommunity-list [<1-500>|<NAME>]
         show ip igmp snooping [mrouter|querier|vlan]
         show ip igmp snooping [mrouter|querier] vlan <1-4095> {on <DEVICE-NAME>}
         show ip igmp snooping vlan <1-4095> {<IP>} {(on <DEVICE-NAME>)}
         show ip interface {<INTERFACE-NAME>|brief|on}
         show ip interface {<INTERFACE-NAME>|brief} {(on <DEVICE-NAME>)}
         show ip nat translations verbose {on <DEVICE-NAME>}
         show ip route {<INTERFACE-NAME>|ge|me1|on|port-channel|pppoe1|vlan|wwan1}
         show ip route {<INTERFACE-NAME>|ge <1-4>|me1|port-channel <1-2>|vlan <1-4094>|
pppoe1|wwan1} {(on <DEVICE-NAME>)}
         show ip ospf {border-router|interface|neighbor|on|route|state}
         show ip ospf {border-router|neighbor|route|on|state} {on <DEVICE-NAME>}
         show ip ospf {interface} {vlan|on}
         show ip ospf {interface} {vlan <1-4094>} {(on <DEVICE-NAME>)}
The
show > ip > ospf
            command is also available under the ‘profile' and ‘device' modes.
Parameters
                     | ip arp | Displays Address Resolution Protocol (ARP) mappings |
                     | <VLAN-NAME> | Optional. Displays ARP mapping on a specified VLAN. Specify the VLAN
                        name. |
                     | on <DEVICE-NAME> | The following keyword is recursive and common to the ‘vlan-name'
                           parameter:
                           on <DEVICE-NAME>
                              – Optional. Displays ARP configuration details on a specified
                                 device
                                 <DEVICE-NAME> – Specify the name of the AP, wireless
                                    controller, or service platform. |
         show ip bgp {<IP>|<IP/M>|community|community-list|filter-list|neighbors|on|
                     | ip bgp | Displays BGP routing table statistics based on the match criteria
                        specified here. Routes matching the specified criteria are filtered. Use
                        available options to filter the information displayed. This command is
                           applicable to the RFS 4000, NX 95XX, and NX 96XX model
                        devices. |
                     | <IP> | Optional. Filters routes matching the specified IP address |
                     | <IP/M> | Optional. Filters routes matching the specified network |
                     | community | Optional. Filters routes based on the community attribute specified. The
                        options are:
                           AA:NN – Filters routes
                              based on the community number (AA: is the autonomous system number
                              (ASN), NN: is the community number within the specified ASN)local-as – Filters
                              routes carrying the local-as attribute (these routes are not sent
                              outside the local AS)no-advertise – Filters
                              routes carrying the no-advertise attribute (these routes are not
                              advertised to any peers)no-export – Filters
                              routes carrying no-export attribute (these routes are not exported to
                              next AS) |
                     | community-list | Optional. Displays routes that are members of communities included in
                        the specified BGP community-list
                           <1-500> –
                              Specify the community-list number.<WORD> – Specify
                              the community-list name. |
                     | filter-list | Optional. Filters routes having AS-path matching the specified AS-path
                        access list. Specify the AS-path ACL name. |
                     | neighbors | Optional. Displays BGP neighbor details. Specify the IP address, to view
                        a specific neighbor details. Use one of the following options to filter
                           information:
                           advertised-routes –
                              Displays route information for routes advertised to the selected
                              neighbor devicereceived-routes –
                              Displays route information for routes received from the selected
                              neighbor deviceroutes – Displays the
                              route information for routes learned from the selected neighbor
                              device If no neighbor IP address is specified, the system displays all
                           neighbor-related routes on the logged device. |
                     | on <DEVICE-NAME> | Optional. Displays BGP routing table statistics on a specified device
                           <DEVICE-NAME> –
                              Specify the name of the AP, wireless controller, or service
                              platform. |
                     | paths | Optional. Displays BGP path details |
                     | prefix-list <PREFIX-LIST-NAME> | Optional. Displays routes confirming to the specified prefix-list
                           <PREFIX-LIST-NAME> – Specify the prefix list name. |
                     | regexp <LINE> | Optional. Displays routes matching the specified AS path regular
                        expression
                           <LINE> – Specify
                              the regular expression. |
                     | route-map <ROUTE-MAP-NAME> | Optional. Displays routes matching the specified route map
                           <ROUTE-MAP-NAME>
                              – Specify the route map name. |
                     | ip ddns | Displays Dynamic Domain Name Server (DDNS) configuration
                        details |
                     | bindings {on <DEVICE-NAME>} | Displays DDNS address bindings
                           on <DEVICE-NAME> – Optional. Displays address bindings on a
                              specified device
                     | ip dhcp | Displays the DHCP server configuration details |
                     | networks | Displays DHCP server network details |
                     | status | Displays DHCP server status |
                     | on <DEVICE-NAME> | The following keyword is common to all of the above parameters:
                           on <DEVICE-NAME> – Optional. Displays server status and network
                              details on a specified device
                     | bindings | Displays DHCP address bindings |
                     | manual | Displays static DHCP address bindings |
                     | on <DEVICE-NAME> | The following keyword is recursive and common to the ‘manual'
                           parameter:
                           on <DEVICE-NAME>
                              – Optional. Displays DHCP address bindings on a specified device
                     | ip extcommunity-list [<1-500>|<NAME>] | Displays the specified extended community list details
                           <1-500> –
                              Specify the extended community number from 1 - 500.<NAME> – Specify
                              the extended community name. This command is applicable to the RFS 4000,  NX 95XX, and NX 96XX model devices. |
{on <DEVICE-NAME>}
                     | ip default-gateways | Displays all learnt default gateways |
                     | ip dhcp-vendor-options | Displays DHCP 43 parameters received from the DHCP server. This output
                        includes the interface from which the option was learned. |
                     | ip domain-name | Displays the DNS default domain |
                     | ip name-server | Displays the DNS name server details |
                     | ip routing | Displays routing status |
                     | on <DEVICE-NAME> | The following keywords are common to all of the above parameters:
                           on <DEVICE-NAME>
                              – Optional. Displays IP related information, based on the parameters
                              passed, on a specified device
                     | ip igmp snooping | Displays the IGMP snooping configuration |
                     | mrouter | Displays the IGMP snooping multicast router (mrouter)
                        configuration |
                     | querier | Displays the IGMP snooping multicast querier
                        configuration |
                     | vlan <1-4095> {on <DEVICE-NAME>} | Displays the IGMP snooping multicast router configuration for a VLAN
                           <1-4095> –
                              Specify the VLAN ID from 1 - 4095.
                                 on
                                    <DEVICE-NAME> – Optional. Displays the IGMP snooping
                                    mrouter configuration on a specified device
                                          wireless controller, or service platform. |
                     | vlan <1-4095> | Displays the VLAN IGMP snooping configuration
                           <1-4095> –
                              Specify the VLAN ID from 1 - 4095. |
                     | <IP> | Optional. Specifies the multicast group IP address |
                     | on <DEVICE-NAME> | The following keyword is recursive and common to the ‘ip' parameter:
                           on <DEVICE-NAME>
                              – Optional. Displays configuration details on a specified device
                     | ip interface | Displays an administrative and operational status of all layer 3
                        interfaces or a specified layer 3 interface |
                     | <INTERFACE-NAME> | Displays a specified interface status. Specify the interface
                        name. |
                     | brief | Displays a brief summary of all interface status and
                        configuration |
                     | on <DEVICE-NAME> | The following keyword is recursive and common to the ‘interface-name'
                        and ‘brief' parameters:
                           on <DEVICE-NAME>
                              – Optional. Displays interface status and summary, based on the
                              parameters passed, on a specified device
                     | ip nat translations | Displays Network Address Translation (NAT) translations |
                     | verbose | Displays detailed NAT translations
                           on <DEVICE-NAME>
                              – Optional.Displays NAT translations on a specified device
         show ip route {<INTERFACE-NAME>|ge <1-4>|me1|port-channel <1-2>|vlan <1-4094>|pppoe1|wwan1}
                     | ip route | Displays route table details. The route tables use flags to distinguish
                        between routes. The different flags are:
                           C – ConnectedG – GatewayO – OSPF routeS – Static route Note: Flags ‘S‘ and ‘O‘
                           identify static learned routes and dynamic learned routes
                           respectively. |
                     | <INTERFACE-NAME> | Optional. Displays route table details for a specified interface.
                        Specify the interface name |
                     | ge <1-4> | Displays GigabitEthernet interface route table details
                           <1-4> – Specify
                              the GigabitEthernet interface index from 1 - 4. |
                     | me1 | Displays FastEthernet interface route table details |
                     | port-channel <1-2> | Displays port channel interface route table details. Specify the port
                        channel index from 1 - 2. |
                     | vlan <1-4095> | Displays VLAN interface route table details. Select the VLAN interface
                        ID from 1 - 4094. |
                     | pppoe1 | Displays PPPoE interface route table details |
                     | wwan1 | Displays Wireless WAN route table details |
                     | on <DEVICE-NAME> | The following keywords are recursive and common to all of the above
                           parameters:
                           on <DEVICE-NAME>
                              – Displays route table details, based on the parameters passed, on a
                              specified device
         show ip ospf {border-router|interface|neighbor|route|on|state}{on <DEVICE-NAME>}
                     | ip ospf | Displays overall OSPF information |
                     | border-router | Optional. Displays details of all the border routers connected |
                     | interface {on| vlan <1-4094>} {on <DEVICE-NAME>} | Optional. Displays details of all the interfaces with OSPF enabled
                           on <DEVICE-NAME>
                              – Optional. Displays specified device detailsvlan <1-4094> –
                              Displays VLAN interface details
                     | neighbor | Optional. Displays an OSPF neighbors list |
                     | route | Optional. Displays OFPS routes information |
                     | state | Optional. Displays an OSPF process state |
                           parameters:
                           on <DEVICE-NAME>
                              – Optional. Displays overall OSPF information, based on the parameters
         nx9500-6C8809(config)#show ip arp
          IP                    MAC              INTERFACE           TYPE
  192.168.13.10        00-02-B3-28-D1-55        vlan1          dynamic
  192.168.13.13        B4-C7-99-6C-88-09        vlan1          dynamic
  192.168.13.2         00-0F-8F-19-BA-4C        vlan1          dynamic
         nx9500-6C8809(config)#show ip interface brief
 INTERFACE          IP-ADDRESS/MASK            TYPE        STATUS   PROTOCOL
 me1                unassigned                 n/a         UP       down
 vlan1              192.168.13.24/24           primary     UP       up
         nx9500-6C8809(config)#show ip route
     DESTINATION         GATEWAY       FLAGS   INTERFACE   METRIC    DISTANCE
  default             192.168.13.2     S       vlan1       0        1
  192.168.13.0/24     0.0.0.0          C       vlan1       0        0
Flags:  C - Connected G - Gateway O - OSPF  B - BGP  S - Static
Gateway: N - Normalized Gateway Address
         nx9500-6C8809(config)#show ip route port-channel 1
192.168.0.0/24    direct          C         me1         0        0
172.18.0.0/24     direct          C         vlan1       0        0
10.2.0.0/24       172.18.0.1      S         vlan1       0        1
default           192.168.13.2    S         vlan192     0        1
192.168.13.0/24   direct          C         vlan192     0        0
         nx9500-6C8809(config)#show ip routing on rfs6000-81742D
IP routing is enabled.
         nx9500-6C8809(config)#show ip dhcp status
State of DHCP server: not-running
         nx9500-6C8809(config)#show ip ospf state
 Maximum number of OSPF routes allowed: 9216
   Number of OSPF routes received: 0
   Ignore-count allowed: 5, current ingore-count: 0
   Ignore-time 60 seconds, reset-time 360 seconds
   Current OSPF process state: Running
