no [area|assignable-power|avoidance-time|channel-list|channel-width|coverage-hole-recovery| enable|group-by|interference-recovery|neighbor-recovery|select-shutdown|smart-ocs-monitoring]
no area <AREA-NAME> channel-list [2.4GHZ|5GHZ]
no assignable-power [2.4GHZ|5GHZ|6GHZ] [max|min]
no [channel-list|channel-width] [2.4GHZ|5GHZ|6GHZ]
no coverage-hole-recovery [client-threshold|coverage-interval|interval|snr-threshold] [2.4GHZ|5GHZ]
no avoidance-time [adaptivity|dfs]
no enable
no group-by [area|floor]
no interference-recovery {channel-hold-time|channel-switch-delta [2.4GHZ|5GHZ|6GHZ]|
client-threshold|interference|neighbor-offset|noise|noise-factor}
         no neighbor-recovery {dynamic-sampling {retries|threshold}|power-hold-time|power-threshold
[2.4GHZ|5GHZ]}
         no select-shutdown {cci-high-threshold|cci-low-threshold|frequency|frequency-limiter}
         no smart-rf-monitoring {awareness-override [schedule <1-3>|threshold]|client-aware [2.4GHZ|5GHZ|6GHZ]|
extended-scan-frequency [2.4GHZ|5GHZ]|frequency [2.4GHZ|5GHZ]|off-channel-duration [2.4GHZ|5GHZ|6GHZ]|
power-save-aware [2.4GHZ|5GHZ]|sample-count [2.4GHZ|5GHZ]|voice-aware [2.4GHZ|5GHZ|6GHZ]}
      no <PARAMETERS>
| no <PARAMETERS> | Negates a command or sets its default. When used in the config Smart RF policy mode, the no command disables or resets the Smart RF policy settings. |
The following example shows the Smart RF policy ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test group-by floor sensitivity custom assignable-power 2.4GHz max 20 assignable-power 2.4GHz min 8 channel-list 2.4GHz 1,12 channel-width 5GHz auto channel-width 2.4GHz auto area test channel-list 2.4GHz 1,2,3 avoidance-time dfs 300 no smart-ocs-monitoring smart-ocs-monitoring frequency 5GHz 3 smart-ocs-monitoring frequency 2.4GHz 3 smart-ocs-monitoring sample-count 5GHz 3 smart-ocs-monitoring extended-scan-frequency 5GHz 0 smart-ocs-monitoring extended-scan-frequency 2.4GHz 9 smart-ocs-monitoring awareness-override schedule 1 12:30 20:30 all interference-recovery client-threshold 255 interference-recovery channel-switch-delta 5GHz 5 interference-recovery channel-switch-delta 2.4GHz 5 neighbor-recovery power-threshold 5GHz -65 neighbor-recovery power-threshold 2.4GHz -65 select-shutdown CCI high threshold -82 select-shutdown CCI low threshold -95 select-shutdown frequency 30 select-shutdown frequency-limiter 5 coverage-hole-recovery interval 5GHz 15 coverage-hole-recovery interval 2.4GHz 15 coverage-hole-recovery coverage-interval 5GHz 5 coverage-hole-recovery coverage-interval 2.4GHz 5 interference-recovery channel-hold-time 180 nx9500-6C8809(config-smart-rf-policy-test)#
nx9500-6C8809(config-smart-rf-policy-test)#no interference-recovery channel-switch-delta 5GHz
         nx9500-6C8809(config-smart-rf-policy-test)#no neighbor-recovery power-threshold 2.4GHz
         nx9500-6C8809(config-smart-rf-policy-test)#no neighbor-recovery power-threshold 5GHz
         nx9500-6C8809(config-smart-rf-policy-test)#no assignable-power 2.4GHz min
         nx9500-6C8809(config-smart-rf-policy-test)#no assignable-power 5GHz max
         The following example shows the Smart RF policy ‘test' settings after the ‘no' commands are executed:
nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test group-by floor sensitivity custom channel-list 2.4GHz 1,12 channel-width 5GHz auto channel-width 2.4GHz auto area test channel-list 2.4GHz 1,2,3 avoidance-time dfs 300 no smart-ocs-monitoring smart-ocs-monitoring frequency 5GHz 3 smart-ocs-monitoring frequency 2.4GHz 3 smart-ocs-monitoring sample-count 5GHz 3 smart-ocs-monitoring extended-scan-frequency 5GHz 0 smart-ocs-monitoring extended-scan-frequency 2.4GHz 9 smart-ocs-monitoring awareness-override schedule 1 12:30 20:30 all interference-recovery client-threshold 255 interference-recovery channel-switch-delta 2.4GHz 5 select-shutdown CCI high threshold -82 select-shutdown CCI low threshold -95 select-shutdown frequency 30 select-shutdown frequency-limiter 5 coverage-hole-recovery interval 5GHz 15 coverage-hole-recovery interval 2.4GHz 15 coverage-hole-recovery coverage-interval 5GHz 5 coverage-hole-recovery coverage-interval 2.4GHz 5 interference-recovery channel-hold-time 180 nx9500-6C8809(config-smart-rf-policy-test)#
