Enables discovery of Bonjour devices and the services they provide on Local or Tunneled VLANs
allow-service <BONJOUR-SERVICE-NAME> [local|tunneled]
allow-service <BONJOUR-SERVICE-NAME> local {instance-name contains <WORD>}
({service-vlans <WORD>})
      allow-service <BONJOUR-SERVICE-NAME> tunneled {instance-name contains <WORD>}
      | allow-service <BONJOUR-SERVICE-NAME> | Configures the services that can be discovered by the
                Bonjour gateway. And also configures the VLANs on which the selected services can be
                  discovered.
| local | Select to enable the discovery of the selected Bonjour Services on the local VLAN |
| instance-name contains <WORD> | Optional. Specifies the selected Bonjour service‘s
                instance name. When specified, the Bonjour service discovery queries contain the
                instance name. of the service to be discovered. This option is useful especially
                  in large distributed, enterprise networks. Use it to create different instances of
                  a Bonjour service for the different organizations or departments (VLANs) within
                  your network. Creating instances allows you to advertise specific service
                  instances for a specific set of VLANs, instead of advertising top-level Bonjour
                  Services to various allocated VLAN(s).
| service-vlans <WORD> | Optional. Configures a VLAN or a list of VLANs on which the selected service is discoverable. When specified, Bonjour discovery queries are delivered to all clients on the specified VLANs. Applicable only if enabling Bonjour Services discovery on local VLANs. |
                  discovered.
| tunneled | Select to enable the discovery of the selected Bonjour Services on tunneled VLANs |
| instance-name contains <WORD> | Optional. Adds a Bonjour Service instance name. If you
                have a large enterprise network, use this option to create different Bonjour Service
                instances for the different organizations or departments (VLANS) within your
                network. Creating instances allows you to advertise specific service instances for a
                specific set of VLANs, instead of advertising top-level Bonjour Services to various
                allocated VLAN(s).
nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#allow-service Afp local
      nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#allow-service Printer lo
cal instance-name contains $Bonjour_Service service-vlans 1,2
      nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#show context bonjour-gw-discovery-policy test allow-service Printer local service-vlans 1-2 instance-name contains $Bonjour_Service allow-service Afp local nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#
Following example configures the string alias named $Bonjour_Service:
nx9500-6C8809(config)#alias string $Bonjour_Service admin nx9500-6C8809(config)#commit nx9500-6C8809(config)#show context include-factory | include alias string alias string $Bonjour_Service admin nx9500-6C8809(config)#
| no | Removes or modifies this Bonjour Gateway Discovery Policy settings |
