cert-key-size
      Configures the size of the key associated with a certificate request
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      cert-key-size [2048|3072|4096]
    Parameters
              | cert-key-size [2048|3072|4096] | Configures the certificate request key size. The options
                  are:
                  2048 – Sets the key size to 2048 bits. This is the default setting.3072 – Sets the key size to 3072 bits4096 – Sets the key size to 4096 bits |
      nx9500-6C8809(config-cmp-policy-test)#cert-key-size 3072
      nx9500-6C8809(config-cmp-policy-test)#show context
crypto-cmp-policy test
 cert-key-size 3072
 ca-server primary host 192.168.8.74 port 8 path cmp
    Related Commands
              | no | Reverts the certificate request key size to default
                (2048 bits) |
