Removes or reverts the selected Ethernet port settings
no [captive-portal-enforcement|cdp|channel-group|description|dot1x|duplex|eee|
ip|ipv6|lacp|lacp-channel-group|lldp|mac-auth|power|qos|shutdown|spanning-tree|speed|switchport|use]
      no [captive-portal-enforcement|channel-group|description|duplex|mac-auth|shutdown|speed]
no [cdp|lldp] [receive|transmit]
no dot1x [authenticator [guest-vlan|host-mode|max-reauth-req|port-control|reauthentication|timeout [quiet-period|reauth-period]]|supplicant]
no eee
no ip [arp [header-mismatch-validation|trust]|dhcp trust]
no ipv6 [dhcpv6 trust|nd [header-mismatch-validation|raguard|trust]]
no [lacp port-priority|lacp-channel-group]
no power {best-effort|limit|priority}
      no qos trust [802.1p|cos|dscp]
no spanning-tree [bpdufilter|bpduguard|force-version|guard|link-type|mst|portfast]
no switchport [access vlan|mode|trunk native tagged]
no use [ip-access-list|ipv6-access-list|mac-access-list] in
no <PARAMETERS>
| no <PARAMETERS> | Removes or reverts this Ethernet port settings based on the parameters passed |
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
nx9500-6C8809(config-profile-default-nx5500-if-ge1)#no cdp nx9500-6C8809(config-profile-default-nx5500-if-ge1)#no duplex
ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#show context interface ge2 eee ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#n ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#no eee ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#show context interface ge2 no eee ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#
