Configures a unique SSID (Service Set Identifier) for this meshpoint. This ID is used to uniquely identify this meshpoint.
meshid <MESH-SSID>
meshid <MESH-SSID>
| meshid | Configures a unique SSID for the meshpoint |
| <MESH-SSID> | The unique SSID configured for this meshpoint Note: The mesh SSID is case sensitive and should not
                           exceed 32 characters. |
nx9500-6C8809(config-meshpoint-test)#meshid TestingMeshPoint
         nx9500-6C8809(config-meshpoint-test)#show context meshpoint test description "This is an example of a meshpoint description" meshid TestingMeshPoint beacon-format mesh-point control-vlan 1 allowed-vlans 1,10-16,18-23 data-rates 2.4GHz bgn data-rates 5GHz an security-mode none no root nx9500-6C8809(config-meshpoint-test)#
| no (meshpoint-config) | Removes the SSID configured for this meshpoint |
