Configures a Bonjour GW Forwarding policy. When configured and applied on the controller, the policy defines the service VLANs (the VLANs on which Bonjour services are running) and client VLANs where clients are present. All Bonjour responses from service VLANs are forwarded to client VLANs. A maximum of 2 (two) policies can be created on a wireless controller or service platform. And only 1 (one) policy can be created on an access point.
bonjour-gw-forwarding-policy <POLICY-NAME>
| <POLICY-NAME> | Specify the Bonjour GW Forwarding policy name. If the policy does not exist, it is created. To receive Bonjour service responses from specific VLANs, specify the VLAN IDs. In the Bonjour GW Forwarding policy configuration mode, provide a list of VLAN IDs from which Bonjour responses can be received (format: 10-20, 25, 30-35). And then specify the list of client VLANs that can access Bonjour services. Execute the bonjour-gw-discovery-policy command to define the Bonjour services allowed on local and tunneled VLANs. To associate a Bonjour GW Forwarding policy with a
                           device or profile, in the profile/device
                           configuration mode, execute the  |
nx9500-6C8809(config)#bonjour-gw-forwarding-policy test nx9500-6C8809(config-bonjour-gw-forwarding-policy-test)#? (config-bonjour-gw-forwarding-policy) commands: forward-bonjour-response Forwards bonjour service response across vlans no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-bonjour-gw-forwarding-policy-test)#
| no | Removes an existing Bonjour GW Forwarding policy |
