profile
      Configures profile related commands.
         If no parameters are given, all profiles are selected.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         profile {anyap|ap505|ap510|containing|filter|nx5500|nx75xx|nx9000|nx9600|vx9000}
         profile {anyap|ap505|ap510|nx5500|nx75xx|nx9000|nx9600|vx9000} <DEVICE-PROFILE-NAME>
         profile {containing <DEVICE-PROFILE-NAME>} {filter type [ap505|ap510||nx75xx|nx9000|nx9600|
vx9000]}
         profile {filter type [ap505|ap510|nx5500|nx75xx|nx9000|nx9600|vx9000]}
      Parameters
         profile {anyap|ap505|ap510|rfs6000|nx5500|nx75xx|nx9000|nx9600|vx9000}
                     | profile <DEVICE-TYPE> <DEVICE-PROFILE-NAME> | Configures device profile commands. If no device profile is specified,
                        the system configures all device profiles. Select ‘anyap‘ to configure a profile applicable to any access
                           point. |
         profile {containing <DEVICE-PROFILE-NAME>} {filter type [ap505|ap510|nx5500|nx75xx|
                     | profile | Configures device profile commands |
                     | containing <DEVICE-PROFILE-NAME> | Optional. Configures profiles that contain a specified sub-string in the
                           hostname
                           <DEVICE-PROFILE-NAME> – Specify a substring in the profile name
                              to filter profiles. |
                     | filter type | Optional. An additional filter used to configure a specific type of
                        device profile. If no device type is specified, the system configures all
                        device profiles.
                           type – Filters profiles by the device type.
                              Select a device type from the following options:
                              The options are: AP505, AP510, NX5500, NX7500,
                              NX9500, NX9600, and VX9000. |
         profile {filter type[ap505|ap510|nx5500|nx75xx|nx9000|nx9600|vx9000]}
                        device profiles.
         <DEVICE>(config)#profile nx9000 test-NX9500
<DEVICE>(config-profile-test-NX9500)#?
Profile Mode commands:
  adopter-auto-provisioning-policy-lookup  Use centralized auto-provisioning
                                           policy when adopted by another
                                           controller
  adoption                                 Adoption configuration
  adoption-mode                            Configure the adoption mode for the
                                           access-points in this RF-Domain
  alias                                    Alias
  application-policy                       Application Poicy configuration
  area                                     Set name of area where the system
                                           is located
  arp                                      Address Resolution Protocol (ARP)
  auto-learn                               Auto learning
  autogen-uniqueid                         Autogenerate a unique id
  autoinstall                              Autoinstall settings
  bridge                                   Ethernet bridge
  captive-portal                           Captive portal
  cdp                                      Cisco Discovery Protocol
  cluster                                  Cluster configuration
  configuration-persistence                Enable persistence of configuration
                                           across reloads (startup config
                                           file)
  controller                               WLAN controller configuration
  critical-resource                        Critical Resource
  crypto                                   Encryption related commands
  database                                 Database command
  device-onboard                           Device-onboarding configuration
  device-upgrade                           Device firmware upgrade
  diag                                     Diagnosis of packets
  dot1x                                    802.1X
  dpi                                      Enable Deep-Packet-Inspection
                                           (Application Assurance)
  dscp-mapping                             Configure IP DSCP to 802.1p
                                           priority mapping for untagged
                                           frames
  eguest-server                            Enable ExtremeGuest Server
                                           functionality
  email-notification                       Email notification configuration
  enforce-version                          Check the firmware versions of
                                           devices before interoperating
  environmental-sensor                     Environmental Sensors Configuration
  events                                   System event messages
  export                                   Export a file
  file-sync                                File sync between controller and
                                           adoptees
  floor                                    Set the floor within a area where
                                           the system is located
  gre                                      GRE protocol
  http-analyze                             Specify HTTP-Analysis configuration
  interface                                Select an interface to configure
  ip                                       Internet Protocol (IP)
  ipv6                                     Internet Protocol version 6 (IPv6)
  l2tpv3                                   L2tpv3 protocol
  l3e-lite-table                           L3e lite Table
  led                                      Turn LEDs on/off on the device
  led-timeout                              Configure the time for the led to
                                           turn off after the last radio state
                                           change
  legacy-auto-downgrade                    Enable device firmware to auto
                                           downgrade when other legacy devices
                                           are detected
  legacy-auto-update                       Auto upgrade of legacy devices
  lldp                                     Link Layer Discovery Protocol
  load-balancing                           Configure load balancing parameter
  logging                                  Modify message logging facilities
  mac-address-table                        MAC Address Table
  mac-auth                                 802.1X
  management-server                        Configure management server address
  memory-profile                           Memory profile to be used on the
                                           device
  meshpoint-device                         Configure meshpoint device
                                           parameters
  meshpoint-monitor-interval               Configure meshpoint monitoring
                                           interval
  min-misconfiguration-recovery-time       Time interval to check controller
                                           connectivity after configuration is
                                           received
  mint                                     MiNT protocol
  misconfiguration-recovery-time           Check controller connectivity after
                                           configuration is received
  neighbor-inactivity-timeout              Configure neighbor inactivity
                                           timeout
  neighbor-info-interval                   Configure neighbor information
                                           exchange interval
  no                                       Negate a command or set its
                                           defaults
  noc                                      Configure the noc related setting
  nsight                                   NSight
  ntp                                      Ntp server WORD
  offline-duration                         Set duration for which a device
                                           remains unadopted before it
                                           generates offline event
  otls                                     Omnitrail Location Server
  power-config                             Configure power mode
  preferred-controller-group               Controller group this system will
                                           prefer for adoption
  preferred-tunnel-controller              Tunnel Controller Name this system
                                           will prefer for tunneling extended
                                           vlan traffic
  radius                                   Configure device-level radius
                                           authentication parameters
  raid                                     RAID
  remote-debug                             Configure remote debug parameters
  remove-override                          Remove configuration item override
                                           from the device (so profile value
                                           takes effect)
  rf-domain-manager                        RF Domain Manager
  router                                   Dynamic routing
  slot                                     PCI expansion Slot
  spanning-tree                            Spanning tree
  traffic-class-mapping                    Configure IPv6 traffic class to
                                           802.1p priority mapping for
                                           untagged frames
  traffic-shape                            Traffic shaping
  trustpoint                               Assign a trustpoint to a service
  tunnel-controller                        Tunnel Controller group this
                                           controller belongs to
  use                                      Set setting to use
  vrrp                                     VRRP configuration
  vrrp-state-check                         Publish interface via OSPF/BGP only
                                           if the interface VRRP state is not
                                           BACKUP
  wep-shared-key-auth                      Enable support for 802.11 WEP
                                           shared key authentication
  zone                                     Configure Zone name
  clrscr                                   Clears the display screen
  commit                                   Commit all changes made in this
                                           session
  do                                       Run commands from Exec mode
  end                                      End current mode and change to EXEC
                                           mode
  exit                                     End current mode and down to
                                           previous mode
  help                                     Description of the interactive help
                                           system
  revert                                   Revert changes
  service                                  Service Commands
  show                                     Show running system information
  write                                    Write running configuration to
                                           memory or terminal
      Related Commands
                     | no | Removes a profile and its associated configurations |
