report-royalty-application
    Enables detection of captive portal
      client‘s usage of a selected (preferred) loyalty application
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      report-loyalty-application {custom-app <APPLICATION-NAME>}
    Parameters
                <APPLICATION-NAME>} | Reports a captive portal client‘s loyalty application
                presence and stores this information in the captive portal‘s user database. The
                client‘s loyalty application detection occurs on the access point to which the
                client is associated. Retail administrators can use this information to assess
                whether patrons‘ loyalty application usage is as per expectation within specific
                retail environments. This option is disabled by default.
                  custom-app <APPLICATION-NAME> – Optional. Uses a custom application
                    definition as match criteria.
                      <APPLICATION-NAME> – Specify the custom
                        application name (should be existing and configured).
                        Ensure that the application specified is available and
                        configured. If not, create an application definition.
                        For more information, see application. If no custom application definition is specified, the system uses
                  localization to detect application presence. |
      nx9500-6C8809(config-captive-portal-test)#report-loyalty-application custom-app
AntiVirus
      nx9500-6C8809(config-captive-portal-test)#show context include-factory | include
 report-loyalty-application custom-app AntiVirus
    Related Commands
              | no | Disables detection of customer-loyalty application presence |
