redirect [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx]
redirect [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000> controller [<CONTROLLER-IP>|<CONTROLLER-HOSTNAME>] [any|cdp-match|dhcp-option|fqdn|ip|ipv6|level| lldp-match|mac|model-number|pool|serial-number|vlan]
redirect [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000> controller [<CONTROLLER-IP>|<CONTROLLER-HOSTNAME>|ipv6] any
redirect[anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000>
controller [<CONTROLLER-IP>|<CONTROLLER-HOSTNAME>|ipv6] [cdp-match <LOCATION-SUBSTRING>|
dhcp-option <DHCP-OPTION>|fqdn <FQDN>|ip [<START-IP> <END-IP>|<IP/MASK>]|ipv6 [<START-IP> <END-IP>|
<IP/MASK>]|level [1|2]|lldp-match <LLDP-STRING>|mac <START-MAC> {<END-MAC>}|
model-number <MODEL-NUMBER>|pool <1-2>|serial-number <SERIAL-NUMBER>|vlan <VLAN-ID>] {upgrade}
| redirect | Adds a redirect adoption rule. The rule applies to the device type selected. Specify the device type and assign a precedence to the rule. The different device types are: AP410, AP460. AP505, AP510, AP560, NX5500, NX7500, NX9500, NX9600, and VX9000. Note: ‘anyap‘ is used in auto provisioning policies to create rules that are
                           applicable to any AP regardless of the model type. Note: An adoptee controller,
                           such as NX5500 can be redirected to another controller (configured to
                           adopt controllers) with a capacity equal to or higher than its own. For
                           more information, see controller |
| precedence <1-10000> | Sets the rule precedence. Rules with lower values get precedence over rules with higher values. |
| controller [<CONTROLLER-IP>| <CONTROLLER-HOSTNAME>|ipv6] | Configures the controller to which the adopting
                           devices are redirected. Specify the controller‘s IP address or
                              hostname.
| any | Indicates any device. Any device seeking adoption is redirected. |
redirect [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-1000>
controller [<CONTROLLER-IP>| <CONTROLLER-HOSTNAME>|ipv6] [cdp-match <LOCATION-SUBSTRING>|
dhcp-option <DHCP-OPTION>|fqdn <FQDN>|ip [<START-IP> <END-IP>|<IP/MASK>]|ipv6[<START-IP>
<END-IP>|<IP/MASK>]|lldp-match <LLDP-STRING>|mac <START-MAC> {<END-MAC>}|model-number
                           more information, see controller. |
                              hostname.
 After specifying the rule precedence and the controller, specify the match criteria. |
| cdp-match <LOCATION-SUBSTRING> | Configures the device location to match, based on
                        CDP snoop strings
| dhcp-option <DHCP-OPTION> | Configures the DHCP options to match DHCP options identify the vendor and DHCP client functionalities. This information is used by the client to convey to the DHCP server that the client requires extra information in a DHCP response.
| fqdn <FQDN> | Configures the FQDN to match FQDN is a domain name that specifies its exact location in the DNS hierarchy. It specifies all domain levels, including its top-level domain and the root domain.
| ip [<START-IP> <END-IP>|<IP/MASK>] | Configures a range of IP addresses and subnet
                        address. Devices having IPv4 addresses within the specified range or are
                        part of the specified subnet are redirected.
| level[1|2] | Configures the routing level
| ipv6 [<START-IP> <END-IP>| <IP/MASK>] | Redirects if a device's IPv6 address matches the
                        specified IP address or is within the specified IP address range
| lldp-match <LLDP-STRING> | Configures the device location to match, based on LLDP snoop string LLDP is a vendor neutral link layer protocol used to advertise a network device‘s identity, capabilities, and neighbors on a local area network.
| mac <START-MAC> {<END-MAC>} | Configures a single or a range of MAC addresses.
                        Devices matching the specified values are redirected.
| model-number <MODEL-NUMBER> | Configures the device model number
| pool <1-2> | Configures the controller pool
| serial-nuber <SERIAL-NUMBER> | Configures the device‘s serial number
| vlan <VLAN-ID> | Configures the VLAN ID
| upgrade | Optional. Upgrades APs before redirecting the device for adoption within the system |
nx9500-6C8809(config-auto-provisioning-policy-test)#redirect ap81xx precedence 6 controller 192.168.13.10 ip 192.168.13.11 192.168.13.15
nx9500-6C8809(config-auto-provisioning-policy-test)#redirect ap7532 precedence 7 controller 192.168.13.10 model-number AP-7532-67030-WR
nx9500-6C8809(config-auto-provisioning-policy-test)#show context auto-provisioning-policy test default-adoption evaluate-always deny ap8432 precedence 1 mac 74-67-F7-07-02-35 deny ap8432 precedence 2 ip 192.168.13.24 102.168.13.26 adopt ap8432 precedence 5 profile default-ap8432 rf-domain TechPubs vlan 1 redirect ap81xx precedence 6 controller 192.168.13.10 ip 192.168.13.11 192.168.13.15 redirect ap7532 precedence 7 controller 192.168.13.10 model-number AP-7532-67030-WR nx9500-6C8809(config-auto-provisioning-policy-test)#
| Removes a redirect rule from this Auto Provisioning Policy |
