nsight-policy (global-config-mode)
    Creates an NSight policy and enters its
      configuration mode. The NSight policy configures parameters that enable controllers or virtual
      controllers (VCs) and RF Domain managers to post periodic-stats, event logs, and configuration
      information (such as RF Domains, location hierarchy, WLANs, device inventory) to a designated
      server host. The server could be an NSight server deployed on an external VM appliance or the ExtremeCloud IQ
        server.Any WiNG controller that is onboarded to XIQ can be managed from XIQ. You can
        use the SSH proxy option on XIQ to open SSH connection with WiNG controller for accessing
        the CLI and web proxy option to launch the GUI. This feature is also supported on WiNG
        access points configured in virtual controller mode.
You can use your existing
          credentials to access WiNG CLI or GUI.
ExtremeCloud IQ server support
          has been introduced in the WiNG 7.3.0.2 and WiNG 7.3.1 firmware. Going forward, WiNG
          devices running on the aforementioned firmware (or successive versions) can securely
          connect to the ExtremeCloud IQ server.
After configuring the NSight policy
        apply the policy in the following contexts:
          - RF Domain - The RF Domain manager posts
            periodic-stats (polled from APs within the RF Domain) and changes in operational
            parameters of APs within the RF Domain to the server host configured in the NSight
            policy.
- WiNG controller or VC (self or profile)
            - The controller or VC posts event logs and configuration information, such as RF
            Domains, location hierarchy, WLANs, device inventory to the server host configured in
            the NSight policy.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      nsight-policy <NSIGHT-POLICY-NAME>
    Parameters
              | <NSIGHT-POLICY-NAME> | Specify the NSight policy name. If a policy with the specified name does not
                exist, it is created. |
      nx9500-6C8809(config)#nsight-policy test
nx9500-6C8809(config-nsight-policy-test)#?
Nsight Policy Mode commands:
  enable              Enable this Nsight policy
  mandatory           Configure mandatory app stats reporting
  no                  Negate a command or set its defaults
  server              Configure Nsight server
  clrscr              Clears the display screen
  commit              Commit all changes made in this session
  end                 End current mode and change to EXEC mode
  exit                End current mode and down to previous mode
  help                Description of the interactive help system
  revert              Revert changes
  service             Service Commands
  show                Show running system information
  write               Write running configuration to memory or terminal
    Related Commands
              | no | Removes an existing NSight policy |
