Enables simultaneous configuration of multiple devices
device {containing|filter}
         device {containing <STRING>} {filter type [ap505|ap510|ex3524|ex3548|rfs4000|nx5500|
nx75xx|nx9000|nx9600|t5|vx9000]}
         device {filter type [ap505|ap510|ex3524|ex3548|rfs4000|nx5500|nx75xx|nx9000|nx9600|
t5|vx9000]}
      device {containing <STRING>} {filter type [ap505|ap510|ex3524|ex3548|rfs4000|nx5500|nx75xx|nx9000|nx9600|
t5|vx9000]}
         | device | Enters a device‘s configuration mode. Use this command to simultaneously configure devices having similar configuration. |
| containing <STRING> | Optional. Configures the string to search for in
                        the device‘s hostname. All devices having hostnames containing the string
                        specified here are filtered, and can be configured simultaneously.
| filter type <DEVICE-TYPE> | Optional. Filters out a specific device type. After specifying the hostname string, select the device type. The options are: AP510, AP505, EX3424, EX3548, RFS4000, NX5500, NX7500, NX9500, NX9600, VX9000, and T5. |
t5|vx9000]}
         | device | Configures a basic device profile |
| filter type <DEVICE-TYPE> | Optional. Filters out a specific device type. The options are: AP510, AP505, EX3424, EX3548, RFS4000, NX5500, NX7500, NX9500, NX9600, VX9000, and T5.. |
ap505-13403B(config)#device filter type ap5
ap510  ap505
ap505-13403B(config)#device filter type ap505 ?
  <cr>
ap505-13403B(config-device-{'type': 'ap505'})#
      | no | Removes multiple devices from the network |
