AP560i Specifications
            AP560i is a cloud-ready, stadium
                optimized, WiFi 6, 802.11ax outdoor access point with two internal antenna. It is
                ideally suited for high-density user environments, such as stadiums, large public
                venues, convention centers and school auditoriums. The AP560i offers flexible deployment
                options and can be mounted under a seat, to a pole, and a wall, thereby ensuring
                exceptional mobile user experience.
                - Radios: 2 radios; 1 IoT radio
                    (2.4 GHz).
- Console Port: RJ45.
- Two Ethernet Ports:
                        - GE1 -
                            10/100/1000/2500/5000 Mbps auto-negotiation Ethernet port, RJ45, with
                            PoE In
- GE2 - 10/100/1000 Mbps
                            auto-negotiation Ethernet port, RJ45, with PoE In
- LEDs: 2 – All LEDs will be on
                    during reset
- One Reset button
- Power: PoE 802.3at; 12VDC
                    external power in connector
- Antennas:
                        - Eight WiFi internal
                            antennas
- One BLE internal
                            antenna
