Defines the captive portal‘s access type. The authentication scheme configured here is applied to wireless clients requesting captive portal guest access to the WiNG network.
access-type [custom-auth-radius|logging|no-auth|radius|registration]
| custom-auth-radius | Specifies the custom user information used for authentication (RADIUS lookup of given information, such as name, e-mail address, telephone, etc.). When configured, accessing clients are required to provide a 1-32 character lookup data string used to authenticate their credentials. When selecting this option, use the custom-auth command to configure the required user information. |
| logging | Enables logging of user access details. |
| no-auth | Defines no authentication required for a guest. Requesting clients are redirected to the captive portal Welcome page without authentication. |
| radius | Enables RADIUS authentication for wireless clients. A requesting client‘s user credentials require authentication before access to the captive portal is permitted. This is the default setting. |
| registration | Enables captive portal‘s clients to self
                        register. When enabled, a requesting client‘s user credentials require
                        authentication locally or through social media credential exchange and
                           validation. If enabled, use the webpage > internal > registration > field command to customize the registration page. If not customized, the default, built-in registration Web page is displayed. |
nx9500-6C8809(config-captive-portal-test)#access-type logging
         nx9500-6C8809(config-captive-portal-test)#show context captive-portal test access-type logging access-time 35 nx9500-6C8809(config-captive-portal-test)#
| no | Removes the captive portal access type or reverts to default (radius) |
