window-size
    (iot-device-type-imagotag-policy)
    Configures the transmission window size
      for messages exchanged between ESL communicator and tags
        - Access Points — AP-8432
- Wireless Controllers — RFS 4000
- Service Platforms — NX 5500, NX 75XX, NX 95XX, NX 96XX, VX 9000
Syntax
      window-size <1-14>
    Parameters
      window-size <1-14>
              | window-size <1-14> | Configures the window size
                  <1-14> – Specify a value from 1 - 14 bytes. The default value is 14
                    bytes. Note: SES-Imagotags recommends NOT to change the default
                setting. |
      nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#window-size 12
      nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#show context
 iot-device-type-imagotag-policy ImagoTagPolicy
  enable
  output-power Level-B
  window-size 12
  payload-size 25
  port 200
  ssl-enable
  fcc-enable
  channel 9
