Define the primary and secondary hop settings. When defined, the primary hop resource is used with no additional considerations when ever it is available.
next-hop [<IP>|<ROUTER-IF-NAME>|pppoe1|serial <SLOT-ID> <PORT-ID> <CHANNEL-GROUP-ID>|
vlan <1-4094>|wwlan1] {<IP>|<ROUTER-IF-NAME>|pppoe1|serial <SLOT-ID> <PORT-ID>
<CHANNEL-GROUP-ID>|vlan <1-4094>|wwlan1}
         | next-hop | Sets the next hop (primary and secondary) for packets satisfying match
                           criteria Note: It is not
                           mandatory to define the secondary hop interface. The secondary hop is
                           used in case the primary hop is unavailable. |
| <IP> | Specifies the primary and secondary next hop router‘s IP address |
| <WORD> | Specifies the layer 3 Interface name (router interface) |
| pppoe1 | Specifies the PPP over Ethernet interface |
| serial <SLOT-ID> <PORT-ID> <CHANNEL-GROUP-ID> | Specifies the serial interface‘s slot, port, and channel group IDs. |
| vlan <1-4094> | Specifies the VLAN interface ID
| wwan1 | Specifies the WAN interface |
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#next-hop vlan 1
         nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#show context route-map 1 match incoming-interface pppoe1 next-hop vlan1 default-next-hop wwan1 mark ip dscp 7 nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#
| no (route-map-config-mode-command) | Disables the next hop router settings |
