Configures the antenna ID on an AP510e model access point profile and device. Use this command to specify the antenna types used with the external antennas.
The ExtremeMobility AP510e access point is a dual-radio access point, with eight, external Wi-Fi antennas grouped into: group-1 (antenna ports 1 to 4) and group-2 (antenna ports 5 to 8).
The antenna-id parameter, specifies the antenna type used in the group-1 and/or group-2 antenna ports. The antenna ports used by the AP to receive/transmit traffic depends on the software mode its running. Refer, following table for information on the antenna group used for the different software modes:
| Antenna Ports | ||
| Software Mode | 2.4/5G Antennas: 1, 2, 3, 4 | 5G Antennas: 5, 6, 7, 8 |
| Mode 1
 Note: This
                    mode requires only FOUR,
                      dual-band antennas connected to ANT sockets 1 to
                    4. Note:  If using this mode,
                    configure antenna-id only for the group 1
                  antennas. | Dual-band 2.4 GHz/5 GHz | None |
| Mode 2
 Note: This
                    mode requires FOUR,
                      dual-band antennas connected to ANT sockets 1 to 4,
                    and FOUR, 5G-band
                    antennas connected to ANT sockets 5 to 8. Note:  If using this mode, configure antenna-id
                    for both group 1 and group 2 antennas. | Dual-band 2.4 GHz/5 GHz | 5 GHz |
| Mode 3
 Note: Requires FOUR, 5G-band
                    antennas connected to ANT sockets 1 to 4, and FOUR,
                      5G-band
                    for both group 1 and group 2 antennas. | 5 GHz | 5 GHz |
antenna-id external [group-1|group-2] <ANTENNA-TYPE>
| antenna-id | Selects the antenna group to use. |
| external | States the antenna is external |
| group-1 | Configures the antenna type used in the group-1 antenna ports (1 to 4). Note: Group-1 antenna configuration is
                  required for all three software modes. Note: Refer to the table above for the
                  supported software modes and the corresponding antenna
                configurations. |
| group-2 | Configures the antenna type used in the group-2 antenna ports (5 to 8 ). Note: Group-2 antenna configuration is ONLY required for software modes 2 & 3.
                   Note: Refer to the table above for the supported software modes and the
                  corresponding antenna configurations. |
| antenna-type | Configures the antenna
                type used The antenna types supported for 'group-1' and 'group-2' antenna ports are: ai-dq04360s, ml-2452-apa2-01, ml-2452-apa2-02, ml-2452-hpa5-036, ml-2452-hpag4a6-01, ml-2452-hpag5a8-01, ml-2452-pna5-01r, ml-2452-pna7-01r, ml-2452-pta4m4-036, ml-2452-sec6m4-036, ws-ai-dq05120. By default no antenna-type is associated with the group-1 and group-2 antenna ports and the radio is disabled. |
Following is the supported software modes for the AP510e access point radios:
| Software Mode 1 |
| Software Mode 2 |
| Software Mode 3 |
ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#antenna-id ?
  group-1  Configure the antenna id on antenna group 1 (2.4/5GHz dual band
           antenna)
  group-2  Configure the antenna id on antenna group 2 (5GHz single band
           antenna)
      ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#antenna-id group-1 ?
  ai-dq04360s         AI-DQ04360S Dual Band, Four Input Omni, 36 Inch Cable
  default             Internal antenna for internal SKU, no antenna for
                      external SKU
  ml-2452-apa2-01     ML-2452-APA2-01 3dBi/4.85dBi, dual band, black
  ml-2452-apa2-02     ML-2452-APA2-02 3dBi/4.85dBi, dual band, white
  ml-2452-hpa5-036    ML-2452-HPA5-036 3dBi/5dBi, dual band, outdoor, white
  ml-2452-hpag4a6-01  ML-2452-HPAG4A6-01 4dBi/7.3dBi, N-type male, dual band,
                      outdoor, white
  ml-2452-hpag5a8-01  ML-2452-HPAG5A8-01
  ml-2452-pna5-01r    ML-2452-PNA5-01R 2.4/5 GHz, Outdoor, Panel, 5 dBi, Beam
                      Width: E-Plane: 65 degrees, H-Plane: 120 degrees
  ml-2452-pna7-01r    ML-2452-PNA7-01R 8/12dBi 68deg Panel
  ml-2452-pta4m4-036  ML-2452-PTA4M4-036 4dBi/5 dBi, 4 port, dual band
  ml-2452-sec6m4-036  ML-2452-SEC6M4-036 DUAL POLARIZED DUAL BAND WIDE BEAM
                      DIRECTIONAL ANTENNA WITH 36 INCH CABLE
  ws-ai-dq05120       WS-AI-DQ05120 DUAL POLARIZED DUAL BAND WIDE BEAM
      ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#antenna-id group-2 ai-dq04360s
ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#show context ap510 94-9B-2C-13-3C-9B use profile default-ap510 use rf-domain default hostname ap510-133C9B no mint mlcp vlan no mint mlcp ip antenna-id group-1 ai-dq04360s interface radio1 interface vlan1 description "Virtual Interface for LAN by Wizard" ip address 192.162.4.159/24 ip address zeroconf secondary no ip dhcp client request options all no virtual-controller no rf-domain-manager capable no adoption-mode ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#
| no | Removes the antenna-id configuration on the selected AP510e profile and device. |
