crypto-auto-ipsec-tunnel commands
Specifies the identity string used for IKE authentication
groupid <WORD> [psk|rsa]
groupid <WORD> [psk [0 <WORD>|2 <WORD>|<WORD>]|rsa]
| <WORD> | Specify a string not exceeding 64 characters. This is the group identity used for IKE exchange for auto IPSec secure peers. After providing a group ID, specify the authentication method used to authenticate peers on the auto IPSec secure tunnel. The options are: psk and rsa. |
| psk [0 <WORD>| 2 <WORD>| <WORD>] | Configures the
                        PSK (pre-shared key) as the authentication type for secure peer
                        authentication on the auto IPSec secure tunnel
| rsa | Configures the
                        RSA (Rivest-Shamir-Adleman) key. RSA is an algorithm for public key cryptography. It is the first algorithm known to be suitable for signing, as well as encryption. This is the default setting. |
Only one group ID is supported on the controller or service platform. All APs, controllers, and service platform must use the same group ID.nx9500-6C8809(config-profile-default-ap8533-crypto-auto-ipsec-secure)#groupid testgroup@123 rsa nx9500-6C8809(config-profile-default-ap8533-crypto-auto-ipsec-secure)#show context crypto auto-ipsec-secure groupid testgroup@123 rsa nx9500-6C8809(config-profile-default-ap8533-crypto-auto-ipsec-secure)#
