pppoe-client
      Displays PPPoE client information. Use
         this command to view PPPoE statistics derived from access to high-speed data and broadband
         networks. PPPoE uses standard encryption, authentication, and compression methods as
         specified by the PPPoE protocol. PPPoE enables point-to-points connection to an ISP over
         existing Ethernet interface.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         show pppoe-client [configuration|status] {on <DEVICE-NAME>}
      Parameters
                     | pppoe-client | Displays PPPoE client information (configuration and status) |
                     | configuration | Displays detailed PPPoE client configuration |
                     | status | Displays detailed PPPoE client status |
                     | on <DEVICE-NAME> | The following keywords are common to ‘configuration' and ‘status'
                           parameters:
                           on <DEVICE-NAME>
                              – Optional. Displays detailed PPPoE client status or configuration on
                              a specified device
                                 <DEVICE-NAME> – Specify the name of the AP, wireless
                                    controller, or service platform. |
         nx9500-6C8809#show pppoe-client configuration
 PPPoE Client Configuration:
|  Mode          : Disabled
|  Service Name  :
|  Auth Type     : pap
|  Username      :
|  Password      : fJx5O+5duPjaOaPuXmtLDQAAAAAmvgEXcQ1+eUK4ByHK4aRi
|  Idle Time     : 600
|  Keepalive     : Disabled
|  Local n/w     : vlan1
|  Static IP     : __wing_internal_not_set__
|  MTU           : 1492
nx9500-6C8809#
