11axTWT
        The IEEE 802.11ax
            standard defines power saving enhancements and improved resource scheduling features
            including scheduled sleep and wake times. The Target Wake Time (TWT) option
            allows devices, APs and stations, to negotiate when and how frequently they will wake up
            to send or receive data. TWT increases device sleep time, thereby substantially
            improving the client device's battery life. Use this command to enable 11ax TWT
                support on the radio. TWT is disabled by default.
        Supported in the
                following platforms:
                - Access Points — AP3000/X, AP5010, AP310i/e, AP410i/e,
                        AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612,
                    AP7632, AP7662, AP8432, AP8533
            ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#11axTWT
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#show context
 interface radio1
  11axSupport
  11axOFDMA both
  11axTWT
  11axBSScolor 20
