running-config
      Displays configuration files (where
         all configured MAC and IP access lists are applied to an interface)
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         show running-config {aaa-policy|application|application-group|application-policy|
association-acl-policy|auto-provisioning-policy|captive-portal-policy|device|database-client-policy|
database-policy|device|device-overrides|dhcp-server-policy|dhcpv6-server-policy|
ex3500-management-policy|ex3500-qos-class-map-policy|ex3500-qos-policy-map|exclude-devices|
firewall-policy|flag-unwritten-changes|guest-management-policy|hide-encrypted-values|
include-factory|interface|ip-access-list|ipv6-access-list|mac-access-list|management-policy|
meshpoint|nsight-policy|profile|radio-qos-policy|rf-domain|roaming-assist-policy|rtl-server-policy|
schedule-policy|smart-rf-policy|url-filter|url-list|web-filter-policy|wlan|wlan-qos-policy}
         show running-config {aaa-policy|application-policy|association-acl-policy|auto-provisioning-policy|
captive-portal-policy|database-client-policy|database-policy|dhcp-server-policy|dhcpv6-server-policy|
ex3500-management-policy|ex3500-qos-class-map-policy|ex3500-qos-policy-map|guest-management-policy|
firewall-policy|management-policy|nsight-policy|radio-qos-policy|roaming-assist-policy|rtl-server-policy|
schedule-policy|smart-rf-policy|web-filter-policy|wlan-qos-policy}<POLICY-NAME> {include-factory}
         show running-config {flag-unwritten-changes}
         show running-config {application <APPLICATION-NAME>|application-group <APPLICATION-GROUP-NAME>}
         show running-config exclude-devices
         show running-config {device [<MAC>|self]} {include-factory}
         show running-config {device-overrides {brief}}
         show running-config {hide-encrypted-values {exclude-devices|include-factory}}
         show running-config {include-factory}
         show running-config {interface} {<INTERFACE-NAME>|ge|include-factory|me|port-channel|
pppoe1|vlan|wwan1}
         show running-config {interface} {<INTERFACE-NAME>|ge <1-4>|include-factory|me1|
port-channel <1-2>|pppoe1|vlan <1-4094>|wwan1} {include-factory}
         show running-config {ip-access-list <IP-ACCESS-LIST-NAME>|ipv6-access-list <IPv6-ACCESS-LIST-NAME>|
mac-access-list <MAC-ACCESS-LIST-NAME} {include-factory}
         show running-config {meshpoint <MESHPOINT-NAME>} {include-factory}
         show running-config {profile [anyap|ap505|ap510|rfs4000|nx5500|nx75xx|nx9000|nx9600|vx9000] <PROFILE-NAME>} {include-factory}
         show running-config {rf-domain <DOMAIN-NAME>} {include-factory}
         show running-config {wlan <WLAN-NAME>} {include-factory}
         show running-config url-filter <URL-FILTER-NAME>
         show running-config url-list <URL-LIST-NAME> {include-factory}
      Parameters
                     | running-config flag-unwritten-changes | Flags unsaved changes in the show >
                           running-config command output. Optionally
                        use the flag-unwritten-changes keyword to view changes
                        that have been committed but not saved in the startup
                        configuration. When used, all unsaved changes are marked
                        with a “===” marker, as shown in the following show >
                        running-config > flag-unwritten-changes
                           output: nx9500-6C8809(config)#show running-config flag-unwritten-changes
! Configuration of NX9500 version 7.1.0.0-114D
version 2.6
client-identity-group default
 load default-fingerprints
client-identity-group test2
===alias encrypted-string $WRITE 2 o5gA2zqj/q/REWi8rTa7vQAAAAh4yA1YNBjqTVf4mMBsGA4i
===alias encrypted-string $enAlias2 2 JI4lPuMaCdMMx7rfBeyIAwAAAAoZ6tR1FfTlFXWvSicTMVZc
--More--
nx9500-6C8809(config)# Execute
                           the write > memory command to save these
                           changes. |
auto-provisioning-policy|captive-portal-policy|database-client-policy|database-policy|
dhcp-server-policy|dhcpv6-server-policy|ex3500-management-policy|ex3500-qos-class-map-policy|
ex3500-qos-policy-map|guest-management-policy|firewall-policy|management-policy|nsight-policy|
radio-qos-policy|roaming-assist-policy|rtl-server-policy|schedule-policy|smart-rf-policy|
web-filter-policy|wlan-qos-policy} <POLICY-NAME> {include-factory}
                     | running-config | Displays current running configuration Optionally, execute the command
                           along with one of the associated keywords to view the running
                           configuration for that top-level object. For example, to view a policy
                           and its configuration, specify the policy type and provide the policy
                              name. Note: If the
                              command is executed without a keyword, the system displays the entire
                              running configuration. |
                     | <POLICY-TYPE> <POLICY-NAME> | Optional. Select the policy type, for example, aaa-policy,
                        auto-provisioning-policy, captive-portal-policy, etc. and then specify the
                        policy name. The system displays the selected policy‘s configuration.
                           <POLICY-NAME> –
                              Specify the name of the policy (should be existing and
                              configured). |
                     | include-factory | The following keyword is common to all policies:
                           include-factory –
                              Optional. Includes factory defaults |
         show running-config {application <APPLICATION-NAME>|apllication-group <APPLICATION-GROUP-NAME>}
                              name. Note: If the
                     | application <APPLICATION-NAME> | Displays an application‘s configuration. The application can be
                        system-provided or user-defined.
                           <APPLICATION-NAME> – Specify the application name (should be
                              existing). |
                     | application-group <APPLICATION-GROUP-NAME> | Displays an application-group‘s configuration
                           <APPLICATION-GROUP-NAME> – Specify the application-group name
                              (should be existing and configured). |
                              name. Note: If the
                     | device [<MAC>|self] | Optional. Displays device configuration
                           <MAC> – Displays
                              a specified device configuration. Specify the MAC address of the
                              device. self – Displays the
                              logged device‘s configuration |
                     | include-factory | This keyword is common to all of the above keywords:
                           include-factory –
                           configuration Optionally, execute the command along with one of the
                           associated keywords to view the running configuration for that top-level
                           object. For example, to view a policy and its configuration, specify the
                           policy type and provide the policy name. Note: If the command is executed
                              without a keyword, the system displays the entire running
                              configuration. |
                     | hide-encrypted-values {exclude-devices|include-factory} | Optional. Replaces all encrypted passwords with the standard characters
                        ****** in the show > running-config output
                           exclude-devices –
                              Optional. Excludes devices from the running configuration
                              displayedinclude-factory –
                              Optional. Includes factory default values in the running configuration
                              displayed |
                     | running-config | Displays current running configuration |
                     | device-overrides brief | Optional. Displays overrides applied at the device‘s configuration
                           brief – Optional. Displays a brief summary of device overrides |
         show running-config {exclude-devices}
                     | exclude-devices | Optional. Excludes device configuration details from the running
                        configuration displayed |
                     | include-factory | Optional. Includes factory defaults |
me1|port-channel <1-2>|pppoe1|vlan <1-4094>|wwan1} {include-factory}
                     | interface | Optional. Displays interface configuration |
                     | <INTERFACE-NAME> | Optional. Displays a specified interface configuration. Specify the
                        interface name. |
                     | ge <1-4> | Optional. Displays GigabitEthernet interface configuration
                           <1-4> – Specify
                              the GigabitEthernet interface index from 1 - 4. |
                     | me1 | Optional. Displays FastEthernet interface configuration |
                     | port-channel <1-2> | Optional. Displays port channel interface configuration
                           <1-2> – Specify
                              the port channel interface index from 1 - 2. |
                     | pppoe1 | Optional. Displays PPP over Ethernet interface configuration |
                     | vlan <1-4094> | Displays VLAN interface configuration
                           <1-4094> –
                              Specify the VLAN interface number from 1 - 4094. |
                     | wwan1 | Optional. Displays Wireless WAN interface configuration |
                     | include-factory | The following keyword is common to all interfaces:
                           include-factory -
<IPv6-ACCESS-LIST-NAME>|mac-access-list <MAC-ACCESS-LIST-NAME} {include-factory}
                              name. Note: If the
                     | ip-access-list <IP-ACCESS-LIST-NAME> | Optional. Displays IP access list configuration
                           <IP-ACCESS-LIST-NAME> – Specify the IP access list name |
                     | <ACL-TYPE> <IP/IPv6/MAC-ACL-NAME> | Optional. Select the ACL type, for example, ip-access-list,
                        ipv6-access-list, or mac-access-list, and then specify the ACL name. The
                        system displays the selected ACL‘s configuration.
                           <IP/IPv6/MAC-ACL-NAME> – Specify the name of the ACL (should be
                     | include-factory | The following keyword is common to the ‘ip-access-list' and
                        ‘mac-access-list' parameters:
                           include-factory -
                     | meshpoint <MESHPOINT-NAME> | Optional. Displays meshpoint configuration
                           <MESHPOINT-NAME>
                              – Specify the meshpoint name |
                     | include-factory | Optional. Includes factory defaults along with running configuration
                        details |
nx9000|nx9600] <PROFILE-NAME>} {include-factory}
                     | profile <DEVICE-TYPE> <PROFILE-NAME> | Optional. Displays current configuration for a specified profile. Select
                        the device type, and then specify the profile name.
                           <DEVICE-TYPE> – Select the device type. The
                              options are: AP505, AP510, RFS4000, NX5500,
                              NX7500, NX9500, NX9600, and VX9000
                                 <PROFILE-NAME> – Specify the profile
                                    name for the selected
                                    <DEVICE-TYPE>. Note: Select the ‘anyap‘
                           option to view the running configuration of any type of
                        device. |
                     | include-factory | Optional. This parameter is common to all profiles. When selected, it
                        includes factory defaults in the output. |
                     | rf-domain <DOMAIN-NAME> | Optional. Displays current configuration for a RF Domain
                           <DOMAIN-NAME> –
                              Displays current configuration for a specified RF Domain. Specify the
                              RF Domain name. |
         show running-config {wlan <WLAN-NAME>}{include-factory}
                     | wlan <WLAN-NAME> | Optional. Displays current configuration for a WLAN
                           <WLAN-NAME> –
                              Displays current configuration for a specified WLAN. Specify the WLAN
                              name. |
                     | url-filter <URL-FILTER-NAME> | Optional. Displays current configuration for the URL filter identified
                        by the <URL-FILTER-NAME> keyword
                           <URL-FILTER-NAME> – Specify the URL filter‘s name. |
                     | url-list <URL-LIST-NAME> | Optional. Displays current configuration for the URL list identified by
                        the <URL-LIST-NAME> keyword
                           <URL-LIST-NAME>
                              – Specify the URL list‘s name. |
         nx9500-6C8809#show running-config device self
version 2.6
ip snmp-access-list default
 permit any
firewall-policy default
 no ip dos tcp-sequence-past-window
mint-policy global-default
management-policy default
 no telnet
 no http server
 https server
 no ftp
 ssh
 user admin password 1 fd07f19c6caf46e5b7963a802d422a708ad39a24906e04667c8642299c8462f1 role superuser access all
--More--
nx9500-6C8809#
         nx9500-6C8809#show running-config profile ap505 default-ap505
 no autoinstall configuration
 no autoinstall firmware
 crypto ikev1 policy ikev1-default
  isakmp-proposal default encryption aes-256 group 2 hash sha
 crypto ikev2 policy ikev2-default
 crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
 crypto ikev1 remote-vpn
 crypto ikev2 remote-vpn
 crypto auto-ipsec-secure
 crypto load-management
 crypto remote-vpn-client
 interface radio1
 interface radio2
 interface ge1
 interface ge2
 interface pppoe1
 use firewall-policy default
 service pm sys-restart
 router ospf
 adoption-mode controller
nx9500-6C8809#
         nx9500-6C8809#show running-config url-filter URL_FILTER_Shopping include-factory
 no description
 blacklist category-type p2p precedence 20 description description
 blacklist category-type news-sports-general category shopping precedence 10 description description
 blockpage path internal
 blockpage internal org-name Your Organization Name
 blockpage internal org-signature Your Organization Name, All Rights Reserved.
 blockpage internal title This URL may have been filtered.
 blockpage internal header The requested URL could not be retrieved.
 blockpage internal footer If you have any questions please contact your IT department.
 blockpage internal content The site you have attempted to reach may be considered inappropriate for access.
 no blockpage internal main-logo
 no blockpage internal small-logo
 no blockpage external
nx9500-6C8809#
         nx9500-6C8809#show running-config management-policy default
 no telnet
 no http server
 https server
 rest-server
 ssh
 user admin password 1 1f61a6bae8aeb0f5205628a5e88a635b8f76eb11f1c44b2dcf1381a8f681f44d role superuser access all
 snmp-server community 0 private rw
 snmp-server community 0 public ro
 snmp-server user snmptrap v3 encrypted des auth md5 0 admin123
 snmp-server user snmpmanager v3 encrypted des auth md5 0 admin123
 t5 snmp-server community public ro 192.168.0.1
 t5 snmp-server community private rw 192.168.0.1
nx9500-6C8809#
