Configures PoE (Power over Ethernet) settings on the selected physical interface. Allows you to monitor port power consumption and configure power usage limits and priorities for each GE port.
power {best-effort|limit <0-40>|priority [critical|high|low]}
| power | Configures power related thresholds for this interface |
| best-effort | Optional. Enables power when the device is
                        not operating from an 802.3at class 4 power source. Note: POE power best effort configuration not
                           available on AP505 and AP510 model access
                           points. |
| limit <0-40> | Optional. Configures the PoE power limit from 0 - 40 Watts. The default is 30 Watts. |
| priority [critical|high|low] | Optional. Configures the PoE power priority
                        on this interface. This is the priority assigned to this
                        port versus the power requirements of the other ports
                        available on the controller/access point.
nx9500-6C8809(config-profile-testAP505-if-ge1)#power limit 30 nx9500-6C8809(config-profile-testAP505-if-ge1)#power priority critical nx9500-6C8809(config-profile-testAP505-if-ge1)#show context interface ge1 ip dhcp trust qos trust dscp qos trust 802.1p power limit 30 power priority critical nx9500-6C8809(config-profile-testAP505-if-ge1)#
| no | Removes PoE settings on this interface |
