Configures a list of destination ports (separated by commas, or using a dash for a range) that are taken into consideration when redirecting client connections
redirection ports <LIST-OF-PORTS>
| ports <LIST-OF-PORTS> | Configures destination ports considered for redirecting client connection A maximum of 16 ports can be specified in a comma-separated list. Standard ports 80 and 443 are always considered for client connections regardless of what‘s entered by the administrator. |
rfs4000-229D58(config-captive-portal-test)#redirection ports 1,2,3
         rfs4000-229D58(config-captive-portal-test)#show context captive-portal test redirection ports 1-3 rfs4000-229D58(config-captive-portal-test)#
| no | Disables redirection of client connection |
