employee-type
Configures a wireless client filter based on the employee type
Syntax
employee-type [any|contains|exact|not-contains]
employee-type [any|exact <WORD>|contains <WORD>|not-contains <WORD>]
Parameters
employee-type
Specifies a wireless client filter based on how the ‘employee type‘, returned by the RADIUS server, matches the provided expression. Select one of the following options: any, contains, exact, or not-contains.
any
No specific employee type associated with this user-defined role. This role can be applied to any wireless client having any employee type (no strings to match). This is the default setting.
contains <WORD>
The role is applied only when the employee type, returned by the RADIUS server, contains the string specified in the role.
  • <WORD> – Specify the string to match (this is case sensitive, and is compared against the employee type returned by the RADIUS server). It should contain the provided expression.
exact <WORD>
The role is applied only when the employee type, returned by the RADIUS server, exactly matches the string specified in the role.
  • <WORD> – Specify the exact string to match (this is case sensitive, and is compared against the employee type returned by the RADIUS server). It should be an exact match.
not-contains <WORD>
The role is applied only when the employee type, returned by the RADIUS server, does not contain the string specified in the role.
  • <WORD> – Specify the string not to match (this is case sensitive, and is compared against the employee type returned by the RADIUS server). It should not contain the provided expression.
nx9500-6C8809(config-role-policy-test-user-role-test1)#employee-type exact consultant
nx9500-6C8809(config-role-policy-test-user-role-user1)#show context
 user-role user1 precedence 1
Related Commands
no
Removes the employee type filter configured with this user-defined role
